problems with new release
Michael Kurz
michael.kurz at autodesk.com
Fri Mar 10 18:19:33 EST 2006
>>Intented to read or write in protected memory
Hi Antonio
I had a similar problem with the same Message.
After I set the Website to run in "High isolation" mode it worked.
Maybe this helps in your case too.
Start the IIS Manager, go to the Properties of your Web site.
At the Bottom of the Tab "Virtual Dircetory" there is a combobox to change this mode.
Micha
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060311/20829101/attachment.html
More information about the Mapguide_users
