[mapguide-users] Selection color and the DWF Viewer API
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Mar 21 10:54:36 EST 2006
Joel,
Here's an archived thread that gives more info on DWF Viewer API:
http://lists.mapserverfoundation.org/pipermail/mse-users/2005-December/0
00335.html
The attachments are zip files - a Word doc and some JavaScript sample
code.  These should give you enough to get going.
To modify the selection color, see the DefaultSelectionColor property
which is part of IAdEMapViewer.  It's a global setting though, and not
per layer.
Walt
  _____
Sent: Monday, March 20, 2006 4:35 PM
Subject: [mapguide-users] Selection color and the DWF Viewer API
Is there any way to change the selection color in the DWF viewer? Our
understanding was that there was going to be a selection color which
would be configurable on a per-layer basis.
Also, (possibly related), I am interested in interacting (using
javascript) with the DWF viewer on a more complex level than that
supplied by the MapGuide Viewer API. However, I haven't been able to
locate the DWF viewer documentation. I looked at
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=5801732
<http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=5801732>
and I didn't see any documentation on some of the API calls that the
Layout is using (SelectionSet, EMapEventRelayer). Can anyone provide me
a link? Will this information be forthcoming?
Joel Carranza
jec at gatekeeper.com
Gatekeeper Systems
626-449-3070 x114
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060321/39e3e6fb/attachment.html
More information about the Mapguide_users mailing list
