[mapguide-users] MGOS build problem on windows 2003
    velen
    vliang at thecarbonproject.com
    Wed Mar 22 15:10:57 EST 2006
Bruce,
FDO was built successfully as we followed along the documentation
("BuildConfigureMapGuideOnWindows.pdf"). According to
"OpenSourceBuild_README.txt", the output binaries are DLLs.
Thank you for the tips!
Velen
  _____
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Tuesday, March 21, 2006 6:24 PM
Subject: RE: [mapguide-users] MGOS build problem on windows 2003
The problem below is that the library "Fdo.lib" could not be found and that
causes lots of server DLLs to fail to build.
The building instructions document says to:
NOTE When performing the build, FDO must be installed to
InstallDir\mapguide-1.0.0\Oem. Do this by using the -o option with
build.bat:
build -o=InstallDir\mapguide-1.0.0\Oem
Could this step have been accidentally missed?
If so could you perform this step and you should be set.
Bruce
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060322/0cecf723/attachment.html
More information about the Mapguide_users
