[mapguide-users] UnitTest TestCoordinateSystem failed on MGOS debug build
velen
vliang at thecarbonproject.com
Fri Mar 24 14:34:03 EST 2006
Thanks to Bruce; We managed to build a debug version of MGOS on Windows
2003. Running unit tests now and found Coordinate System failed. It looks
like PROJ.4 failed to be initialized. We checked %path% and permission of
proj.dll - those seemed okay.
Please advice! Thanks.
Error messages:
Running Coordinate System tests. (PROJ4)
Testing coordinate system OGC WKTs.
ERROR 6: Failed to initialize PROJ.4 with `+proj=omerc +lat_0=0 +lonc=0
+alpha=0
+k=1 +x_0=0 +y_0=0 +ellps=bessel
+towgs84=674.374,15.056,405.346,0.0,0.0,0.0,0.
0 +units=m +no_defs '.
lat_0 = 0 or 90 or alpha = 90
The coordinate system is invalid. PROJCS["CH1903+ / LV95", GEOGCS["CH1903+",
DAT
UM["CH1903+", SPHEROID["Bessel 1841", 6377397.155, 299.1528128,
AUTHORITY["EPSG"
,"7004"]], TOWGS84[674.374, 15.056, 405.346, 0.0, 0.0, 0.0, 0.0],
AUTHORITY["EPS
G","6150"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
UNIT["degree of
angle",0.017453292519943295], AXIS["Geodetic latitude",NORTH],
AXIS["Geodetic l
ongitude",EAST], AUTHORITY["EPSG","4150"]], PROJECTION["Oblique_Mercator"],
PARA
METER["semi_major", 6377397.155], PARAMETER["semi_minor",
6356078.962818189], PA
RAMETER["central_meridian", 0.0], PARAMETER["latitude_of_origin", 0.0],
PARAMETE
R["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
PARAMETER["false_northi
ng", 0.0], UNIT["metre",1.0], AXIS["Easting",EAST], AXIS["Northing",NORTH],
AUTH
ORITY["EPSG","2056"]]
Could not create coordinate system forward transformation with specified
coordin
ate systems.
Exception occurred in method MgCoordinateSystem.MgCoordinateSystem at line
76 in
file
d:\projects\mapguide-1.0.0\common\service\coordinatesystem\coordinatesyste
m.cpp.
_____
From: velen [mailto:vliang at thecarbonproject.com]
Sent: Wednesday, March 22, 2006 3:11 PM
Subject: RE: [mapguide-users] MGOS build problem on windows 2003
Bruce,
FDO was built successfully as we followed along the documentation
("BuildConfigureMapGuideOnWindows.pdf"). According to
"OpenSourceBuild_README.txt", the output binaries are DLLs.
Thank you for the tips!
Velen
_____
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Tuesday, March 21, 2006 6:24 PM
The problem below is that the library "Fdo.lib" could not be found and that
causes lots of server DLLs to fail to build.
The building instructions document says to:
NOTE When performing the build, FDO must be installed to
InstallDir\mapguide-1.0.0\Oem. Do this by using the -o option with
build.bat:
build -o=InstallDir\mapguide-1.0.0\Oem
Could this step have been accidentally missed?
If so could you perform this step and you should be set.
Bruce
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060324/0dcd67f3/attachment.html
More information about the Mapguide_users
