[mapguide-users] MGOS build problem on windows 2003
velen vliang at thecarbonproject.com
Thu Mar 23 09:11:52 EST 2006
Bruce,
I tried rebuilding FDO again and you're right. It didn't build at all. The
problem is the build.bat under fdo folder. It stopped because the label
"start_build"
Not found.
Thanks again,
Velen
  _____
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Tuesday, March 21, 2006 6:24 PM
Subject: RE: [mapguide-users] MGOS build problem on windows 2003
The problem below is that the library "Fdo.lib" could not be found and that
causes lots of server DLLs to fail to build.
The building instructions document says to:
NOTE When performing the build, FDO must be installed to
InstallDir\mapguide-1.0.0\Oem. Do this by using the -o option with
build.bat:
build -o=InstallDir\mapguide-1.0.0\Oem
Could this step have been accidentally missed?
If so could you perform this step and you should be set.
Bruce
  _____
From: velen [mailto:vliang at thecarbonproject.com]
Sent: Tuesday, March 21, 2006 3:57 PM
Subject: [mapguide-users] MGOS build problem on windows 2003
We're experiencing difficulty building mapguide open source on a Windows
2003 server (standard edition). There were a few link errors when building
"Server" solution; most of them are LNK1104: can not open file. There were
no error in the previous steps when building FDO and OEM.
Any suggestion will be appreciated. Thank you for your help in advance!
Velen Liang | www.TheCarbonProject.com
Error messages as follow:
1>------ Build started: Project: ServerManager, Configuration: Debug Win32
2>------ Build started: Project: GwsCommon, Configuration: Debug Win32
1>Linking...
1>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
1>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\ServerManager\BuildLog.h
tm"
1>ServerManager - 1 error(s), 0 warning(s)
3>------ Build started: Project: ServerBase, Configuration: Debug Win32
3>Linking...
2>Linking...
3>LINK : fatal error LNK1104: cannot open file
'..\..\..\lib\debug\mgservermanagerd.lib'
2>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
2>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\GwsCommon\BuildLog.htm"
2>GwsCommon - 1 error(s), 0 warning(s)
3>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\ServerBase\BuildLog.htm"
3>ServerBase - 1 error(s), 0 warning(s)
4>------ Build started: Project: GwsQueryEngine, Configuration: Debug Win32
5>------ Build started: Project: ServerResourceService, Configuration: Debug
Win32 ------
4>Linking...
4>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
4>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\GwsQueryEngine\BuildLog.
htm"
4>GwsQueryEngine - 1 error(s), 0 warning(s)
5>Linking...
5>LINK : fatal error LNK1104: cannot open file
6>------ Build started: Project: Stylization, Configuration: Debug Win32
5>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Resource\BuildL
og.htm"
5>ServerResourceService - 1 error(s), 0 warning(s)
7>------ Build started: Project: ServerFeatureService, Configuration: Debug
Win32 ------
7>Linking...
7>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
7>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Feature\BuildLo
g.htm"
7>ServerFeatureService - 1 error(s), 0 warning(s)
8>------ Build started: Project: ServerAdminService, Configuration: Debug
Win32 ------
8>Linking...
8>LINK : fatal error LNK1104: cannot open file
6>Linking...
8>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\ServerAdmin\Bui
ldLog.htm"
8>ServerAdminService - 1 error(s), 0 warning(s)
6>LINK : fatal error LNK1104: cannot open file 'GisCommon.lib'
6>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Common\obj\debug\Stylization\BuildLog.htm
6>Stylization - 1 error(s), 0 warning(s)
9>------ Build started: Project: ServerSiteService, Configuration: Debug
Win32 ------
9>Linking...
9>LINK : fatal error LNK1104: cannot open file
'..\..\..\lib\debug\mgserverresourceserviced.lib'
9>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Site\BuildLog.h
tm"
9>ServerSiteService - 1 error(s), 0 warning(s)
10>------ Build started: Project: ServerMappingService, Configuration: Debug
Win32 ------
11>------ Build started: Project: ServerDrawingService, Configuration: Debug
Win32 ------
10>Linking...
10>LINK : fatal error LNK1104: cannot open file 'Fdo.lib'
10>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Mapping\BuildLo
g.htm"
10>ServerMappingService - 1 error(s), 0 warning(s)
11>Linking...
11>LINK : fatal error LNK1104: cannot open file
11>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Drawing\BuildLo
g.htm"
11>ServerDrawingService - 1 error(s), 0 warning(s)
12>------ Build started: Project: ServerRenderingService, Configuration:
Debug Win32 ------
12>Linking...
12>LINK : fatal error LNK1104: cannot open file
'..\..\..\lib\debug\mgservermappingserviced.lib'
12>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Rendering\Build
Log.htm"
12>ServerRenderingService - 1 error(s), 0 warning(s)
13>------ Build started: Project: ServerTileService, Configuration: Debug
Win32 ------
13>Linking...
13>LINK : fatal error LNK1104: cannot open file
13>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\Services\Tile\BuildLog.h
tm"
13>ServerTileService - 1 error(s), 0 warning(s)
14>------ Build started: Project: ServerFactory, Configuration: Debug Win32
14>Linking...
14>LINK : fatal error LNK1104: cannot open file
'..\..\..\lib\debug\mgserversiteserviced.lib'
14>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\ServerFactory\BuildLog.h
tm"
14>ServerFactory - 1 error(s), 0 warning(s)
15>------ Build started: Project: ServerCore, Configuration: Debug Win32
15>Linking...
15>LINK : fatal error LNK1181: cannot open input file
'..\..\lib\debug\mgserversiteserviced.lib'
15>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\ServerCore\BuildLog.htm"
15>ServerCore - 1 error(s), 0 warning(s)
16>------ Build started: Project: UnitTesting, Configuration: Debug Win32
16>Linking...
16>LINK : fatal error LNK1104: cannot open file 'GisCommon.lib'
16>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\UnitTesting\BuildLog.htm
16>UnitTesting - 1 error(s), 0 warning(s)
17>------ Build started: Project: PostBuild, Configuration: Debug Win32
17>Performing Makefile project actions
17>Microsoft (R) Program Maintenance Utility Version 8.00.50727.42
17>Copyright (C) Microsoft Corporation.  All rights reserved.
17>NMAKE : fatal error U1073: don't know how to make
'..\..\..\Common\bin\debug\MgStylizationd.dll'
17>Stop.
17>Project : error PRJ0019: A tool returned an error code from "Performing
Makefile project actions"
17>Build log was saved at
"file://d:\Projects\mapguide-1.0.0\Server\obj\debug\PostBuild\BuildLog.htm"
17>PostBuild - 2 error(s), 0 warning(s)
========== Build: 0 succeeded, 17 failed, 6 up-to-date, 0 skipped ==========
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060323/e405d01f/attachment.html
More information about the Mapguide_users mailing list
