[mapguide-users] SDF Question
    Randy Glen Johnson
    rjohnson at maintenanceconnection.com
    Thu Mar 23 16:38:24 EST 2006
They are different will name the same and retest.  Thanks!
Best Regards,
Randy Glen Johnson
Programmer Analyst
Maintenance Connection, Inc.
1-888-567-3434 ext 800
http://www.maintenanceconnection.com <http://www.maintenanceconnection.com/>
-----Original Message-----
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, March 23, 2006 1:37 PM
Subject: RE: [mapguide-users] SDF Question
That's weird, it sounds almost like it didn't find or didn't like the DBF
file. Is your DBF file named the same (including case) as your SHP file and
is it in the same directory as the SHP file?
  _____
From: Randy Glen Johnson [mailto:rjohnson at maintenanceconnection.com]
Sent: Thursday, March 23, 2006 4:33 PM
There is only the single item to select from.  the other fields are not
there.
Best Regards,
Randy Glen Johnson
Programmer Analyst
Sent: Thursday, March 23, 2006 1:32 PM
In Studio, in the Layer Editor where the properties are listed, you need to
check the checkboxes for the ones you want displayed on selection.
Traian
  _____
Sent: Thursday, March 23, 2006 4:28 PM
I take that back. I am getting the single value "FeatID" but nothing else.
there were at least 6 columns in the dbf file .
Best Regards,
Randy Glen Johnson
Programmer Analyst
Sent: Thursday, March 23, 2006 1:17 PM
SDF is the MapGuide proprietary spatial data format.
If you choose to convert SHP to SDF, both the SHP and DBF will be combined
into the resulting SDF file. In general, the data is the same, but you can
expect better performance with SDF. So far there is no simple tool that lets
you view the data in the same way that Excel allows you to view DBF files
for example.
Traian
  _____
Sent: Thursday, March 23, 2006 4:06 PM
Subject: [mapguide-users] SDF Question
I have some questions regarding SDF files.
My source data is .SHP files with dbf data files
Using Autodesk's MapGuide Studio Preview, I loaded my shape files.  It
appears that sdf files were created from wither the shape files or the dbf
files.  I am not sure which it used since I cant see the data.  Somewhere I
found an option to create a sdf file but I am not familiar with sdf files.
What tool do I use to look at data in a sdf file?  Looking on the web only
indicated that sql-ce uses that datatype.  I don't have sql-ce.  any
information and suggestions would be greatly appreciated.
Best Regards,
Randy Glen Johnson
Programmer Analyst
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060323/b653f6b8/attachment.html
More information about the Mapguide_users
