[mapguide-users] Check if service is running?
Willem Schwarte
willem at giskit.nl
Wed May 3 10:14:40 EDT 2006
We have purchased a tool from www.restartservices.com
<http://www.restartservices.com/> (pro version) which restarts any
failed services (even across domains). It also has the option to send an
email once a service has been restarted. ( 100 $)
So far I have had 3 e-mails...
Willem
Van: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Verzonden: dinsdag 2 mei 2006 8:45
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] Check if service is running?
Well, I made some headway on this, but ran into a bug along the way:
https://mapguide.osgeo.org/servlets/Scarab?id=MG269
I could have sworn that I had reported this earlier, but I couldn't find
it in the PT. Basically NET START "MapGuide Server" does not work
because of a name conflict with the "Server" service. Anyone else see
this? The SC command (possibly another XP/2k3-specific command) appears
to work because it only accepts the service name.
You can download a draft PHP CLI health monitoring utility here:
http://www.jasonbirch.com/files/mghealthmonitor.zip
Note, this utility is probably XP/Win2k3-specific. Let me know what you
think.
Jason
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Mon 2006-05-01 3:02 PM
Subject: RE: [mapguide-users] Check if service is running?
I wish Windows had the same kind of consistent command line tools that
unix does. I'm trying to think of a way to deal with this across
Win2k/XP/Win2k3, but short of using the Sysinternals tools I'm drawing a
blank. ps and grep would really come in handy.
- The Windows KILL command doesn't appear to have a mechanism for
identifying the process ID beforehand.
- The TASKKILL command appears to have everything we need, but it isn't
available in 2000
I think I'm going to take the easy way out and use TASKKILL, with
alternate instructions for downloading and using pskill.
Jason
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060503/d7cab0c2/attachment.html
More information about the Mapguide_users
