[mapguide-users] Buffer tool in the AJAX viewer
Butler, Juan P
jpbutler at co.pinellas.fl.us
Wed May 3 09:34:44 EDT 2006
I tried it with the sample application. That uses the Sheboygan
dataset, correct? Doesn't work there either.
Does the map need to be in a certain coordinate system for the buffer to
work?
- Juan
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, May 03, 2006 1:14 AM
Subject: RE: [mapguide-users] Buffer tool in the AJAX viewer
Are you using the Sheboygan dataset or your own?
If your own, I'm betting it's a problem with the units of reference of
the map. The buffering works just fine for me with the sample dataset.
Jason
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Tue 2006-05-02 9:13 PM
Subject: [mapguide-users] Buffer tool in the AJAX viewer
Has anyone been able to get the buffering to work in the AJAX viewer.
No matter what value I put in the distance and no matter what unit of
measure I choose, it just makes the same big red buffer that takes up
the whole map. Does this not work in the AJAX viewer?
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060503/0d0aaf24/attachment.html
More information about the Mapguide_users
