[mapguide-users] IIS Configuration of Mapguide OS - testing web server extensions fails
Chris White
chris.white at keytraffic.com
Wed May 3 09:08:26 EDT 2006
Jason,
Thanks for the help - the problem ended up being that the
aspnet.isapi.dll Web Service Extension was missing.
Thanks again for the help
Chris
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: 02 May 2006 16:47
Subject: RE: [mapguide-users] IIS Configuration of Mapguide OS - testing
Hi Chris,
404 errors are annoying because they're Microsoft's catch-all. It's
better for security, but harder to troubleshoot.
The first thing you should do is make sure that the file is not actually
missing and that you have the correct URL. Navigate to that file in IIS
Admin right-click and choose "Browse".
If that works, make sure that extended logging is configured for IIS,
and check the subcode and any system errors that may be causing the 404.
This page has a good explanation on how to troubleshoot 404s:
http://www.microsoft.com/technet/prodtechnol/WindowsServer2003/Library/I
IS/0f4ac79a-dc2b-4a5f-89c1-d57266aa6ffe.mspx?mfr=true
Some possibilities include ASP.NET 2.0 not being allowed in Web Service
Extensions, ASP.NET has being enabled for that web server, or the .aspx
extension not being correctly associated with the aspnet.isapi.dll file.
Jason
From: Chris White [mailto:chris.white at keytraffic.com]
Subject: [mapguide-users] IIS Configuration of Mapguide OS - testing web
I'm attempting to install MapGuide OS on Windows 2003 Server IIS 6. I
have followed the instructions in the 'Installing and Configuring on
Windows' document and the Map Agent test and Site Administrator test
both are fine. However when I attempt the web server extension test with
the following url:
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060503/675bf83d/attachment.html
More information about the Mapguide_users
