[mapguide-users] Buffer tool in the AJAX viewer
Andy Morsell
amorsell at spatialgis.com
Wed May 3 11:15:28 EDT 2006
On both of my installs (one XP, one Win 2000, both .NET) with my
application, whenever I try to do a buffer, I get this error after hitting
the Done button: "Attempted to read or write protected memory. This is
often an indication that other memory is corrupt".
With the sample Sheboygan application running on the same machines, I see
the exact same symptoms you describe below on one machine, but it works as
expected on the other.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Tuesday, May 02, 2006 9:14 PM
Subject: [mapguide-users] Buffer tool in the AJAX viewer
Has anyone been able to get the buffering to work in the AJAX viewer. No
matter what value I put in the distance and no matter what unit of measure I
choose, it just makes the same big red buffer that takes up the whole map.
Does this not work in the AJAX viewer?
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060503/e332b7c6/attachment.html
More information about the Mapguide_users
