[mapguide-users] OnSelection Event?
Jason Birch Jason.Birch at nanaimo.ca
Fri May 5 04:11:38 EDT 2006
I think that the answer to that might be in the DWF Viewer API thread from yesterday. (Base64 encoded version of the feature's key?)  I didn't follow it all that closely though.
If that's correct, then you'd set up a server-side script that takes that ID, performs a query against the layer/id, and retrieves your required attributes.
Jason
Sent: Fri 2006-05-05 1:03 AM
Subject: RE: [mapguide-users] OnSelection Event?
Cool. Changing the default handler to my own function. I'm gonna check this out next.
Maybe you have got an answer on my question about the xml that is returned?
Willem
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060505/e66eabe8/attachment.bin
More information about the Mapguide_users mailing list
