[mapguide-users] OnSelection Event?
Willem Schwarte
willem at giskit.nl
Fri May 5 04:23:49 EDT 2006
I have tried that decode64 function with the value from this key
<ID>rBAAAA==</ID> but it returned some weird characters..
What should I use to query the layer to get the attributes? Is there an
example of this somewhere. I'm looking at the web api reference, it
would be easier if there were short examples with this. What service
should I use? It's just not yet very clear to me how it all works
exactly.
Van: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Verzonden: vrijdag 5 mei 2006 10:12
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] OnSelection Event?
I think that the answer to that might be in the DWF Viewer API thread
from yesterday. (Base64 encoded version of the feature's key?) I didn't
follow it all that closely though.
If that's correct, then you'd set up a server-side script that takes
that ID, performs a query against the layer/id, and retrieves your
required attributes.
Jason
Sent: Fri 2006-05-05 1:03 AM
Subject: RE: [mapguide-users] OnSelection Event?
Cool. Changing the default handler to my own function. I'm gonna check
this out next.
Maybe you have got an answer on my question about the xml that is
returned?
Willem
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060505/853c81c9/attachment.html
More information about the Mapguide_users
