[mapguide-users] Installing mapguide
Javier de la Torre jatorre at gmail.com
Fri May 5 08:06:18 EDT 2006
Sorry,
I had to start from scratch again :(
By the way, the build_apt script does not work when using a different
prefix. For example this:
./build_apt.sh -prefix /usr/local/servers -port 80 -with-tomcat
compiles fine but at the end Apache doe snot start because:
"Bringing Apache online...
/usr/local/servers/webserverextensions/apache2/bin ~/mapguide_install/LinuxApt
httpd: could not open document config file
/usr/local/mapguideopensource/webserverextensions/apache2/conf/httpd.conf"
So, seems that in the build file does not replace the
mapguideopensource prefix somewhere needed by apache.
I will run it on the default so is no problem for me.
Javier.
On 5/5/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> Hmm, I don't think we build that library so it probably won't make a difference -- it's a PostgreSQL library and I'm not sure why it needs it... Could you run "ldd mgserver" and see what other libraries it is complaining about.
> Traian
>         -----Original Message-----
>         From: Javier de la Torre [mailto:jatorre at gmail.com]
>         Sent: Fri 5/5/2006 5:38 AM
>         To: users at mapguide.osgeo.org
>         Cc:
>         Subject: Re: [mapguide-users] Installing mapguide
>         HI Trian,
>         Today I tried to start from scratch again with the modifications that
>         you gave me yesterday.
>         I manage to make and make install this time, but I believe there were
>         some errors (sorry I was not there when it executed and it was in a
>         batch...).
>         After doing the make / make install I tried to run mgserver.sh and
>         this is what I got:
>         [root at synthesys bin]# ./mgserver.sh
>         /usr/local/mapguideopensource/server/bin /usr/local/
>         ./mgserver: error while loading shared libraries: libpq.so.4: cannot
>         open shared object file: No such file or directory
>         So this is probably because there were some errors in the building no?
>         I will try the whole process again, but this time I will check if it
>         fails somewhere in the process.
>         Javier.
>         On 04/05/2006, at 20:29, Traian Stanev wrote:
>         > Looks like it's still complaining about ACE. Actually, ACE is supposed
>         > to build as part of the build_oem.sh script. However, when you ran
>         > build_oem.sh, ACE probably failed but did not exit the script (the
>         > script in the released tar has that problem), so it was really broken
>         > from the start. I don't know how much this has messed up the build
>         > environment, so what I would do is to clean out the mapguide-1.0.0
>         > directory completely, unzip the mapguide source again, then apply this
>         > change *before* building anything.
>         > Traian
>         > Sent: Thursday, May 04, 2006 2:16 PM
>         > I am loading lot of data in a PostGIS database so I am bored :)
>         > I tried modifying this as you said and now I got a different error...
>         > I could try to upgrade to gcc 4 but this is hard, this is a
>         > dependencies nightmare...
>         > For your info this is the error I get now:
>         > de-1.0.0/Server/src/UnitTesting/.libs
>         > /usr/bin/ld: cannot find -lACE
>         > collect2: ld returned 1 exit status
>         > make[3]: *** [mgserver] Error 1
>         > make[3]: Leaving directory
>         > `/root/mapguide_install/mapguide-1.0.0/Server/src/Core'
>         > make[2]: *** [all-recursive] Error 1
>         > make[2]: Leaving directory
>         > `/root/mapguide_install/mapguide-1.0.0/Server/src'
>         > make[1]: *** [all-recursive] Error 1
>         > make[1]: Leaving directory
>         > `/root/mapguide_install/mapguide-1.0.0/Server'
>         > make: *** [all-recursive] Error 1
>         > On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
>         >> OK. This more or less matches what I was seeing -- I was trying to
>         >> compile on gentoo with gcc 3.4 yesterday. It has to do with some
>         >> templates in the ACE component. If I fix it I will send you the patch
>         >> needed to the ACE global header.
>         >> If you are feeling bored until then, you could try opening
>         >> ./Oem/ACE/ACE_wrappers/ace/Global_Macros.h and replace the two
>         >> occurences of (__GNUC__ >= 4) by (__GNUC__ >= 3). However, I am not
>         > sure
>         >> this is sufficient, since I haven't gotten through the whole ACE
>         >> build
>         >> successfully yet.
>         >> Or you could try a different version of gcc but that's probably more
>         >> painful if you don't have one installed already.
>         >> Traian
>         >> Sent: Thursday, May 04, 2006 1:35 PM
>         >> gcc (GCC) 3.4.4 20050721 (Red Hat 3.4.4-2)
>         >>> I think I have seen this problem before. What version of gcc are you
>         >>> using?
>         >>> Sent: Thursday, May 04, 2006 1:03 PM
>         >>> Ok... I hope this is enough:
>         >>> make[2]: Entering directory
>         >>> `/root/mapguide_install/mapguide-1.0.0/Common/Service'
>         >>> if /bin/sh ../../libtool --mode=compile --tag=CXX g++
>         >>> -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>         >>> -DPACKAGE_VERSION=\"1.0.0\" -DPACKAGE_STRING=\"mapguide\ 1.0.0\"
>         >>> -DPACKAGE_BUGREPORT=\"http://www.mapguide.osgeo.org\"
>         >>> -DPACKAGE=\"mapguide\" -DVERSION=\"1.0.0\" -DSTDC_HEADERS=1
>         >>> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
>         >>> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
>         >>> -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
>         >>> -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1
>         >>> -DHAVE_NETDB_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1
>         >>> -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1
>         >>> -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1  -I. -I.
>         >>> -IController -ICoordinateSystem -IData -IException -IGeometry
>         >>> -IMapLayer -INet -IServices -ISystem -IUtil -I../Security
>         >>> -I../MdfParser -I../MdfModel -I../../Oem/ACE/ACE_wrappers
>         >>> -I../../Oem/geos-2.2.0/source/headers
>         >>> -I../../Oem/dbxml-2.2.13/xerces-c-src/src -I../../Oem/proj-4.4.9/src
>         >>> -I../../Oem/gdal-1.3.0/ogr -I../../Oem/gdal-1.3.0/port
>         >>> -I../../Common/CoordinateSystem    -g -D_DEBUG -MT
>         >>> ServiceControllerBuild.lo -MD -MP -MF
>         >>> ".deps/ServiceControllerBuild.Tpo" -c -o ServiceControllerBuild.lo
>         >>> `test -f 'Controller/ServiceControllerBuild.cpp' || echo
>         >>> './'`Controller/ServiceControllerBuild.cpp; \
>         >>> then mv -f ".deps/ServiceControllerBuild.Tpo"
>         >>> ".deps/ServiceControllerBuild.Plo"; else rm -f
>         >>> ".deps/ServiceControllerBuild.Tpo"; exit 1; fi
>         >>>  g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
>         >>> -DPACKAGE_VERSION=\"1.0.0\" "-DPACKAGE_STRING=\"mapguide 1.0.0\""
>         > -IController
>         >>> -ICoordinateSystem -IData -IException -IGeometry -IMapLayer -INet
>         >>> -IServices -ISystem -IUtil -I../Security -I../MdfParser
>         > -I../MdfModel
>         >>> -I../../Oem/ACE/ACE_wrappers -I../../Oem/geos-2.2.0/source/headers
>         >>> -c Controller/ServiceControllerBuild.cpp  -fPIC -DPIC -o
>         >>> .libs/ServiceControllerBuild.o
>         >>> In file included from
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.h:940,
>         >>>                  from
>         >> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:18,
>         >>>                  from ../../Oem/ACE/ACE_wrappers/ace/Acceptor.h:24,
>         >>>                  from ./AceCommon.h:56,
>         >>>                  from Controller/Controller.cpp:18,
>         >>>                  from Controller/ServiceControllerBuild.cpp:18:
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp: In member
>         >>> function `int ACE_Hash_Map_Manager_Ex<EXT_ID, INT_ID, HASH_KEY,
>         >>> COMPARE_KEYS, ACE_LOCK>::close_i()':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:158: error:
>         >>> expected class-name before '(' token
>         >>> COMPARE_KEYS, ACE_LOCK>::unbind_all_i()':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:190: error:
>         >>> COMPARE_KEYS, ACE_LOCK>::unbind_i(ACE_Hash_Map_Entry<EXT_ID,
>         >>> INT_ID>*)':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:289: error:
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:286,
>         >>>                  from
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:26,
>         >>>                  from
>         >> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:25,
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In member
>         > function
>         >>> `void ACE_Unbounded_Queue<T>::delete_nodes()':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:133: error:
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In destructor
>         >>> `ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:153: error:
>         > function
>         >>> `int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:223: error:
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.h:307,
>         >>>                  from
>         >> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:34,
>         >>>                  from
>         > ../../Oem/ACE/ACE_wrappers/ace/Containers.h:69,
>         >>>                  from
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:27,
>         >>>                  from
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In member function
>         >>> `void ACE_Unbounded_Set<T>::delete_nodes()':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:107: error:
>         > expected
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In destructor
>         >>> `ACE_Unbounded_Set<T>::~ACE_Unbounded_Set()':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:126: error:
>         > expected
>         >>> `int ACE_Unbounded_Set<T>::remove(const T&)':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:230: error:
>         > expected
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:1986,
>         >>>                  from
>         >>>                  from
>         >>>                  from
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function
>         >>> `void ACE_Unbounded_Stack<T>::delete_all_nodes()':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:171: error: expected
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In destructor
>         >>> `ACE_Unbounded_Stack<T>::~ACE_Unbounded_Stack()':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:239: error: expected
>         >>> `int ACE_Unbounded_Stack<T>::pop(T&)':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:275: error: expected
>         >>> `int ACE_Unbounded_Stack<T>::remove(const T&)':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:334: error: expected
>         >>> `int ACE_Ordered_MultiSet<T>::remove(const T&)':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1582: error:
>         > expected
>         >>> `void ACE_Ordered_MultiSet<T>::delete_nodes()':
>         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1786: error:
>         > expected
>         >>> make[2]: *** [ServiceControllerBuild.lo] Error 1
>         >>> make[1]: *** [check-recursive] Error 1
>         >>> `/root/mapguide_install/mapguide-1.0.0/Common'
>         >>> make: *** [check-recursive] Error 1
>         >>> On 5/4/06, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
>         >>>> You need to show us more of the error trace...
>         >>>> Sent: Thursday, May 04, 2006 12:58 PM
>         >>>> Ups...
>         >>>> Now it fails somehwere else. Now I get this at the end of "make"
>         >>>> Any idea of what can this be?
>         >>>> Thanks.
>         >>>> On 5/4/06, Javier de la Torre <jatorre at gmail.com> wrote:
>         >>>>> Thanks all,
>         >>>>> I finally did a yum install libjpeg-devel and this installed the
>         >>>>> requiered libraries.
>         >>>>> Seems that I passed this step now :)
>         >>>>> It could be interesting to include in the documentation that the
>         >>>>> package that is needed is libjpeg-devel. Most people can then do
>         > a
>         >>>>> up2date or yum or apt-get to install it easily.
>         >>>>> Thanks again.
>         >>>>> Javier.
>         >>>>> On 5/4/06, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
>         >>>>>> You might have to specify --enable-shared as an input to the
>         >>>> configure
>         >>>>>> script.
>         >>>>>> Jason
>         >>>>>> Sent: Thursday, May 04, 2006 09:36
>         >>>>>> no, there is nothing there...
>         >>>>>> Am I installing the correct library? In the documentation it
>         >> says:
>         >>>>>> The libjpeg.so library is required. It is installed by default
>         >>> with
>         >>>> most
>         >>>>>> Linux distributions. If you do not have it, you can download
>         > the
>         >>>> source
>         >>>>>> from the Independent JPEG Group: www.ijg.org.
>         >>>>>> I downloaded from there:
>         >>>>>> http://www.ijg.org/files/jpegsrc.v6b.tar.gz
>         >>>>>> Now I am not sure...
>         >>>>>> JAvier.
>         >>>>>>> Did it put it under /usr/local/include by any chance?
>         >>>>>>> Sent: Thursday, May 04, 2006 12:23 PM
>         >>>>>>> Yes, I was logged as root.
>         >>>>>>> The file /usr/include/jpeglib.h does not exist.
>         >>>>>>> I downloaded the jpeg-6b and installed it but does not seems
>         >> to
>         >>>>>>> include this file. It copies others to usr/local/bin.
>         >>>>>>> Thanks.
>         >>>>>>>> Were you logged in as root when you did make install? Do
>         > you
>         >>>> have
>         >>>>>>>> jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
>         >>>>>>>> Traian
>         >>>>>>>> Sent: Thursday, May 04, 2006 12:09 PM
>         >>>>>>>> Subject: [mapguide-users] Installing mapguide
>         >>>>>>>> Hi,
>         >>>>>>>> I am installing mapguide right now, but I am having some
>         >>>> problems
>         >>>>>>>> following the instructions on the PDF file.
>         >>>>>>>> I am trying to use all the default settings on an Intel
>         > with
>         >>> Red
>         >>>> Hat
>         >>>>>>> 9.
>         >>>>>>>> First I installed Apache, Tomcat and PHP (APT) using the
>         >>>> provided
>         >>>>>>>> package. Everything seems to be fine, the servers are
>         >>> available
>         >>>> and
>         >>>>>>>> everyhting worked fine.
>         >>>>>>>> Then I download the Mapguide server an Mapguider server
>         >>>> extensions
>         >>>>>>>> and I build the OEMcomponents. This also seems to compile
>         >>> fine.
>         >>>>>>>> IMake 1.0: Build Successful ........................
>         >>>>>>>> Done building OEM components .......................
>         >>>>>>>> Then I go and try to build and install the default
>         >>>> configuration:
>         >>>>>>>> aclocal    I get this:
>         >>>>>>>> acinclude.m4:7: warning: underquoted definition of
>         >>>> MAP_HELP_STRING
>         >>>>>>>>   run info '(automake)Extending aclocal'
>         >>>>>>>>   or see
>         >>>> http://sources.redhat.com/automake/automake.html#Extending-aclocal
>         >>>>>>>> acinclude.m4:12: warning: underquoted definition of
>         >> MAP_SUBST
>         >>>>>>>> acinclude.m4:19: warning: underquoted definition of
>         >>>> MAP_FAST_OUTPUT
>         >>>>>>>> acinclude.m4:25: warning: underquoted definition of
>         >>>>>>> MAP_GEN_CONFIG_VARS
>         >>>>>>>> acinclude.m4:67: warning: underquoted definition of
>         >>>>>>>> MAP_GENERATE_MAKEFILES
>         >>>>>>>> acinclude.m4:74: warning: underquoted definition of
>         >> MAP_OUTPUT
>         >>>>>>>> acinclude.m4:83: warning: underquoted definition of
>         >>>>>>>> MAP_DEFINE_TYPE_RLIM_T
>         >>>>>>>> acinclude.m4:108: warning: underquoted definition of
>         >>>>>>>> MAP_SUBST_EXPANDED_ARG
>         >>>>>>>> acinclude.m4:115: warning: underquoted definition of
>         >>>>>>>> MAP_EXPORT_ARGUMENTS
>         >>>>>>>> libtoolize --force OK
>         >>>>>>>> automake --add-missing --copy   OK
>         >>>>>>>> autoconf    OK
>         >>>>>>>> ./configure   OK
>         >>>>>>>> make OK
>         >>>>>>>> make check OK
>         >>>>>>>> make install  get into troubles... After lot of messages I
>         >>> start
>         >>>>>>>> getting errors, this is the first one:
>         >>>>>>>> BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or
>         >> directory
>         >>>>>>>> BOpcodeHandler.cpp:4970: error: field `jerr' has
>         > incomplete
>         >>> type
>         >>>>>>>> And I can not continue following the instructions :(
>         >>>>>>>> Anybody can help?
>         >>>>>>>> Thanks in advance.
>         >>>>>>>> Javier.
>         >>>>>>>> - To unsubscribe, e-mail:
>         >> users-unsubscribe at mapguide.osgeo.org
>         >>>>>>>> For additional commands, e-mail:
>         >> users-help at mapguide.osgeo.org
>         >>>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>         >>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
