[mapguide-users] Installing mapguide
Javier de la Torre jatorre at gmail.com
Fri May 5 09:07:47 EDT 2006
Ok... Now it seems that I got it fine until the "make check" where it
proposes to report here.
This is what I got when I did "make"
  (cd .libs && rm -f libMapGuideJavaApi.la && ln -s
../libMapGuideJavaApi.la libMapGuideJavaApi.la)
make[4]: Leaving directory
`/root/mapguide_install/mapguide-1.0.0/Web/src/JavaApi'
make[3]: Leaving directory
make[3]: Entering directory `/root/mapguide_install/mapguide-1.0.0/Web/src'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Web/src'
make[2]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Web/src'
make[2]: Entering directory `/root/mapguide_install/mapguide-1.0.0/Web'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Web'
make[1]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Web'
make[1]: Entering directory `/root/mapguide_install/mapguide-1.0.0'
make[1]: Nothing to be done for `all-am'.
make[1]: Leaving directory `/root/mapguide_install/mapguide-1.0.0'
[root at synthesys mapguide-1.0.0]#
Doesn't seem to have any error, but it also doesn't look like a great success :)
Then I do the make check and this is the result:
Making check in Core
`/root/mapguide_install/mapguide-1.0.0/Server/src/Core'
make  check-TESTS
make[4]: Entering directory
GDAL_DATA=/root/mapguide_install/mapguide-1.0.0/Oem/gdal-1.3.0/data
PROJ_LIB=/root/mapguide_install/mapguide-1.0.0/Oem/proj-4.4.9/nad
/root/mapguide_install/mapguide-1.0.0/Server/src/Core/.libs/lt-mgserver:
error while loading shared libraries: libpq.so.4: cannot open shared
object file: No such file or directory
FAIL: unittest.sh
1 of 1 tests failed
Please report to http://www.mapguide.osgeo.org
make[4]: *** [check-TESTS] Error 1
make[3]: *** [check-am] Error 2
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Server/src'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Server'
make: *** [check-recursive] Error 1
If I do a a make install seems to work but when running the server I
get the same error (that seems to be detected by make check) with the
libpq.so.4 library missing.
When I run ldd mgserver the only missing library seems to be
libpq.so.4 => not found (or at least this is where it stops)
I will try to find the library...
Thanks.
Javier.
On 5/5/06, Javier de la Torre <jatorre at gmail.com> wrote:
> Sorry,
> I had to start from scratch again :(
> By the way, the build_apt script does not work when using a different
> prefix. For example this:
> ./build_apt.sh -prefix /usr/local/servers -port 80 -with-tomcat
> compiles fine but at the end Apache doe snot start because:
> "Bringing Apache online...
> /usr/local/servers/webserverextensions/apache2/bin ~/mapguide_install/LinuxApt
> httpd: could not open document config file
> /usr/local/mapguideopensource/webserverextensions/apache2/conf/httpd.conf"
> So, seems that in the build file does not replace the
> mapguideopensource prefix somewhere needed by apache.
> I will run it on the default so is no problem for me.
> Javier.
> On 5/5/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> > Hmm, I don't think we build that library so it probably won't make a difference -- it's a PostgreSQL library and I'm not sure why it needs it... Could you run "ldd mgserver" and see what other libraries it is complaining about.
> > Traian
> >         -----Original Message-----
> >         From: Javier de la Torre [mailto:jatorre at gmail.com]
> >         Sent: Fri 5/5/2006 5:38 AM
> >         To: users at mapguide.osgeo.org
> >         Cc:
> >         Subject: Re: [mapguide-users] Installing mapguide
> >         HI Trian,
> >         Today I tried to start from scratch again with the modifications that
> >         you gave me yesterday.
> >         I manage to make and make install this time, but I believe there were
> >         some errors (sorry I was not there when it executed and it was in a
> >         batch...).
> >         After doing the make / make install I tried to run mgserver.sh and
> >         this is what I got:
> >         [root at synthesys bin]# ./mgserver.sh
> >         /usr/local/mapguideopensource/server/bin /usr/local/
> >         ./mgserver: error while loading shared libraries: libpq.so.4: cannot
> >         open shared object file: No such file or directory
> >         So this is probably because there were some errors in the building no?
> >         I will try the whole process again, but this time I will check if it
> >         fails somewhere in the process.
> >         Javier.
> >         On 04/05/2006, at 20:29, Traian Stanev wrote:
> >         > Looks like it's still complaining about ACE. Actually, ACE is supposed
> >         > to build as part of the build_oem.sh script. However, when you ran
> >         > build_oem.sh, ACE probably failed but did not exit the script (the
> >         > script in the released tar has that problem), so it was really broken
> >         > from the start. I don't know how much this has messed up the build
> >         > environment, so what I would do is to clean out the mapguide-1.0.0
> >         > directory completely, unzip the mapguide source again, then apply this
> >         > change *before* building anything.
> >         > Traian
> >         > Sent: Thursday, May 04, 2006 2:16 PM
> >         > I am loading lot of data in a PostGIS database so I am bored :)
> >         > I tried modifying this as you said and now I got a different error...
> >         > I could try to upgrade to gcc 4 but this is hard, this is a
> >         > dependencies nightmare...
> >         > For your info this is the error I get now:
> >         > de-1.0.0/Server/src/UnitTesting/.libs
> >         > /usr/bin/ld: cannot find -lACE
> >         > collect2: ld returned 1 exit status
> >         > make[3]: *** [mgserver] Error 1
> >         > make[2]: *** [all-recursive] Error 1
> >         > make[1]: *** [all-recursive] Error 1
> >         > make: *** [all-recursive] Error 1
> >         > On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> >         >> OK. This more or less matches what I was seeing -- I was trying to
> >         >> compile on gentoo with gcc 3.4 yesterday. It has to do with some
> >         >> templates in the ACE component. If I fix it I will send you the patch
> >         >> needed to the ACE global header.
> >         >> If you are feeling bored until then, you could try opening
> >         >> ./Oem/ACE/ACE_wrappers/ace/Global_Macros.h and replace the two
> >         >> occurences of (__GNUC__ >= 4) by (__GNUC__ >= 3). However, I am not
> >         > sure
> >         >> this is sufficient, since I haven't gotten through the whole ACE
> >         >> build
> >         >> successfully yet.
> >         >> Or you could try a different version of gcc but that's probably more
> >         >> painful if you don't have one installed already.
> >         >> Traian
> >         >> Sent: Thursday, May 04, 2006 1:35 PM
> >         >> gcc (GCC) 3.4.4 20050721 (Red Hat 3.4.4-2)
> >         >>> I think I have seen this problem before. What version of gcc are you
> >         >>> using?
> >         >>> Sent: Thursday, May 04, 2006 1:03 PM
> >         >>> Ok... I hope this is enough:
> >         >>> `/root/mapguide_install/mapguide-1.0.0/Common/Service'
> >         >>> if /bin/sh ../../libtool --mode=compile --tag=CXX g++
> >         >>> -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
> >         >>> -DPACKAGE_VERSION=\"1.0.0\" -DPACKAGE_STRING=\"mapguide\ 1.0.0\"
> >         >>> -DPACKAGE_BUGREPORT=\"http://www.mapguide.osgeo.org\"
> >         >>> -DPACKAGE=\"mapguide\" -DVERSION=\"1.0.0\" -DSTDC_HEADERS=1
> >         >>> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
> >         >>> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
> >         >>> -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
> >         >>> -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1
> >         >>> -DHAVE_NETDB_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1
> >         >>> -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1
> >         >>> -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1  -I. -I.
> >         >>> -IController -ICoordinateSystem -IData -IException -IGeometry
> >         >>> -IMapLayer -INet -IServices -ISystem -IUtil -I../Security
> >         >>> -I../MdfParser -I../MdfModel -I../../Oem/ACE/ACE_wrappers
> >         >>> -I../../Oem/geos-2.2.0/source/headers
> >         >>> -I../../Oem/dbxml-2.2.13/xerces-c-src/src -I../../Oem/proj-4.4.9/src
> >         >>> -I../../Oem/gdal-1.3.0/ogr -I../../Oem/gdal-1.3.0/port
> >         >>> -I../../Common/CoordinateSystem    -g -D_DEBUG -MT
> >         >>> ServiceControllerBuild.lo -MD -MP -MF
> >         >>> ".deps/ServiceControllerBuild.Tpo" -c -o ServiceControllerBuild.lo
> >         >>> `test -f 'Controller/ServiceControllerBuild.cpp' || echo
> >         >>> './'`Controller/ServiceControllerBuild.cpp; \
> >         >>> then mv -f ".deps/ServiceControllerBuild.Tpo"
> >         >>> ".deps/ServiceControllerBuild.Plo"; else rm -f
> >         >>> ".deps/ServiceControllerBuild.Tpo"; exit 1; fi
> >         >>>  g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
> >         >>> -DPACKAGE_VERSION=\"1.0.0\" "-DPACKAGE_STRING=\"mapguide 1.0.0\""
> >         > -IController
> >         >>> -ICoordinateSystem -IData -IException -IGeometry -IMapLayer -INet
> >         >>> -IServices -ISystem -IUtil -I../Security -I../MdfParser
> >         > -I../MdfModel
> >         >>> -I../../Oem/ACE/ACE_wrappers -I../../Oem/geos-2.2.0/source/headers
> >         >>> -c Controller/ServiceControllerBuild.cpp  -fPIC -DPIC -o
> >         >>> .libs/ServiceControllerBuild.o
> >         >>> In file included from
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.h:940,
> >         >>>                  from
> >         >> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:18,
> >         >>>                  from ../../Oem/ACE/ACE_wrappers/ace/Acceptor.h:24,
> >         >>>                  from ./AceCommon.h:56,
> >         >>>                  from Controller/Controller.cpp:18,
> >         >>>                  from Controller/ServiceControllerBuild.cpp:18:
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp: In member
> >         >>> function `int ACE_Hash_Map_Manager_Ex<EXT_ID, INT_ID, HASH_KEY,
> >         >>> COMPARE_KEYS, ACE_LOCK>::close_i()':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:158: error:
> >         >>> expected class-name before '(' token
> >         >>> COMPARE_KEYS, ACE_LOCK>::unbind_all_i()':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:190: error:
> >         >>> COMPARE_KEYS, ACE_LOCK>::unbind_i(ACE_Hash_Map_Entry<EXT_ID,
> >         >>> INT_ID>*)':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:289: error:
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:286,
> >         >>>                  from
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:26,
> >         >>>                  from
> >         >> ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:25,
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In member
> >         > function
> >         >>> `void ACE_Unbounded_Queue<T>::delete_nodes()':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:133: error:
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In destructor
> >         >>> `ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:153: error:
> >         > function
> >         >>> `int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:223: error:
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.h:307,
> >         >>>                  from
> >         >> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:34,
> >         >>>                  from
> >         > ../../Oem/ACE/ACE_wrappers/ace/Containers.h:69,
> >         >>>                  from
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:27,
> >         >>>                  from
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In member function
> >         >>> `void ACE_Unbounded_Set<T>::delete_nodes()':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:107: error:
> >         > expected
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In destructor
> >         >>> `ACE_Unbounded_Set<T>::~ACE_Unbounded_Set()':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:126: error:
> >         > expected
> >         >>> `int ACE_Unbounded_Set<T>::remove(const T&)':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:230: error:
> >         > expected
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:1986,
> >         >>>                  from
> >         >>>                  from
> >         >>>                  from
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function
> >         >>> `void ACE_Unbounded_Stack<T>::delete_all_nodes()':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:171: error: expected
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In destructor
> >         >>> `ACE_Unbounded_Stack<T>::~ACE_Unbounded_Stack()':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:239: error: expected
> >         >>> `int ACE_Unbounded_Stack<T>::pop(T&)':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:275: error: expected
> >         >>> `int ACE_Unbounded_Stack<T>::remove(const T&)':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:334: error: expected
> >         >>> `int ACE_Ordered_MultiSet<T>::remove(const T&)':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1582: error:
> >         > expected
> >         >>> `void ACE_Ordered_MultiSet<T>::delete_nodes()':
> >         >>> ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1786: error:
> >         > expected
> >         >>> make[2]: *** [ServiceControllerBuild.lo] Error 1
> >         >>> `/root/mapguide_install/mapguide-1.0.0/Common'
> >         >>> On 5/4/06, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
> >         >>>> You need to show us more of the error trace...
> >         >>>> Sent: Thursday, May 04, 2006 12:58 PM
> >         >>>> Ups...
> >         >>>> Now it fails somehwere else. Now I get this at the end of "make"
> >         >>>> Any idea of what can this be?
> >         >>>> Thanks.
> >         >>>> On 5/4/06, Javier de la Torre <jatorre at gmail.com> wrote:
> >         >>>>> Thanks all,
> >         >>>>> I finally did a yum install libjpeg-devel and this installed the
> >         >>>>> requiered libraries.
> >         >>>>> Seems that I passed this step now :)
> >         >>>>> It could be interesting to include in the documentation that the
> >         >>>>> package that is needed is libjpeg-devel. Most people can then do
> >         > a
> >         >>>>> up2date or yum or apt-get to install it easily.
> >         >>>>> Thanks again.
> >         >>>>> Javier.
> >         >>>>> On 5/4/06, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> >         >>>>>> You might have to specify --enable-shared as an input to the
> >         >>>> configure
> >         >>>>>> script.
> >         >>>>>> Jason
> >         >>>>>> Sent: Thursday, May 04, 2006 09:36
> >         >>>>>> no, there is nothing there...
> >         >>>>>> Am I installing the correct library? In the documentation it
> >         >> says:
> >         >>>>>> The libjpeg.so library is required. It is installed by default
> >         >>> with
> >         >>>> most
> >         >>>>>> Linux distributions. If you do not have it, you can download
> >         > the
> >         >>>> source
> >         >>>>>> from the Independent JPEG Group: www.ijg.org.
> >         >>>>>> I downloaded from there:
> >         >>>>>> http://www.ijg.org/files/jpegsrc.v6b.tar.gz
> >         >>>>>> Now I am not sure...
> >         >>>>>> JAvier.
> >         >>>>>>> Did it put it under /usr/local/include by any chance?
> >         >>>>>>> Sent: Thursday, May 04, 2006 12:23 PM
> >         >>>>>>> Yes, I was logged as root.
> >         >>>>>>> The file /usr/include/jpeglib.h does not exist.
> >         >>>>>>> I downloaded the jpeg-6b and installed it but does not seems
> >         >> to
> >         >>>>>>> include this file. It copies others to usr/local/bin.
> >         >>>>>>> Thanks.
> >         >>>>>>>> Were you logged in as root when you did make install? Do
> >         > you
> >         >>>> have
> >         >>>>>>>> jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
> >         >>>>>>>> Traian
> >         >>>>>>>> Sent: Thursday, May 04, 2006 12:09 PM
> >         >>>>>>>> Subject: [mapguide-users] Installing mapguide
> >         >>>>>>>> Hi,
> >         >>>>>>>> I am installing mapguide right now, but I am having some
> >         >>>> problems
> >         >>>>>>>> following the instructions on the PDF file.
> >         >>>>>>>> I am trying to use all the default settings on an Intel
> >         > with
> >         >>> Red
> >         >>>> Hat
> >         >>>>>>> 9.
> >         >>>>>>>> First I installed Apache, Tomcat and PHP (APT) using the
> >         >>>> provided
> >         >>>>>>>> package. Everything seems to be fine, the servers are
> >         >>> available
> >         >>>> and
> >         >>>>>>>> everyhting worked fine.
> >         >>>>>>>> Then I download the Mapguide server an Mapguider server
> >         >>>> extensions
> >         >>>>>>>> and I build the OEMcomponents. This also seems to compile
> >         >>> fine.
> >         >>>>>>>> IMake 1.0: Build Successful ........................
> >         >>>>>>>> Done building OEM components .......................
> >         >>>>>>>> Then I go and try to build and install the default
> >         >>>> configuration:
> >         >>>>>>>> aclocal    I get this:
> >         >>>>>>>> acinclude.m4:7: warning: underquoted definition of
> >         >>>> MAP_HELP_STRING
> >         >>>>>>>>   run info '(automake)Extending aclocal'
> >         >>>>>>>>   or see
> >         >>>> http://sources.redhat.com/automake/automake.html#Extending-aclocal
> >         >>>>>>>> acinclude.m4:12: warning: underquoted definition of
> >         >> MAP_SUBST
> >         >>>>>>>> acinclude.m4:19: warning: underquoted definition of
> >         >>>> MAP_FAST_OUTPUT
> >         >>>>>>>> acinclude.m4:25: warning: underquoted definition of
> >         >>>>>>> MAP_GEN_CONFIG_VARS
> >         >>>>>>>> acinclude.m4:67: warning: underquoted definition of
> >         >>>>>>>> MAP_GENERATE_MAKEFILES
> >         >>>>>>>> acinclude.m4:74: warning: underquoted definition of
> >         >> MAP_OUTPUT
> >         >>>>>>>> acinclude.m4:83: warning: underquoted definition of
> >         >>>>>>>> MAP_DEFINE_TYPE_RLIM_T
> >         >>>>>>>> acinclude.m4:108: warning: underquoted definition of
> >         >>>>>>>> MAP_SUBST_EXPANDED_ARG
> >         >>>>>>>> acinclude.m4:115: warning: underquoted definition of
> >         >>>>>>>> MAP_EXPORT_ARGUMENTS
> >         >>>>>>>> libtoolize --force OK
> >         >>>>>>>> automake --add-missing --copy   OK
> >         >>>>>>>> autoconf    OK
> >         >>>>>>>> ./configure   OK
> >         >>>>>>>> make OK
> >         >>>>>>>> make check OK
> >         >>>>>>>> make install  get into troubles... After lot of messages I
> >         >>> start
> >         >>>>>>>> getting errors, this is the first one:
> >         >>>>>>>> BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or
> >         >> directory
> >         >>>>>>>> BOpcodeHandler.cpp:4970: error: field `jerr' has
> >         > incomplete
> >         >>> type
> >         >>>>>>>> And I can not continue following the instructions :(
> >         >>>>>>>> Anybody can help?
> >         >>>>>>>> Thanks in advance.
> >         >>>>>>>> Javier.
> >         >>>>>>>> - To unsubscribe, e-mail:
> >         >> users-unsubscribe at mapguide.osgeo.org
> >         >>>>>>>> For additional commands, e-mail:
> >         >> users-help at mapguide.osgeo.org
> >         >>>>>>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> >         >>>>>> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
