[mapguide-users] Unable to connect with Studio
Jason Birch Jason.Birch at nanaimo.ca
Fri May 12 14:06:35 EDT 2006
You can enable both assemblies in the same Web Service Extensions definition; then you can switch between the two at will.
Jason
Subject: RE: [mapguide-users] Unable to connect with Studio
In IIS you need to go into the Web Service Extensions and edit the mapagent entry and point to the mapagent.exe instead of the dll.  It's a good guess that they must match between the .fcgi entry and the Web Service Extensions.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060512/6e76c65f/attachment.bin
More information about the Mapguide_users mailing list
