[mapguide-users] Adding URL and tooltip to generated layer
Alain Lebatard alain.lebatard at autodesk.com
Tue May 16 17:50:09 EDT 2006
Hi Juan,
There is a known problem with maptips/hyperlinks not showing in the AJAX
viewer if the layer is not selectable. Could it  be the same problem
here?
Alain
  _____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Monday, May 15, 2006 1:12 PM
Subject: [mapguide-users] Adding URL and tooltip to generated layer
Hello:
I've got the layer creation pretty much down, but I'm having some issues
with adding the URL and the tooltip info for the markers.   Has anyone
been able to do this?   I left the Tooltip in the XML definition file
for the layer.  I hard coded with a value and it did not come up when
adding the markers to the map.
Any info is appreciated.
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060516/dde25a87/attachment.html
More information about the Mapguide_users mailing list
