[mapguide-users] Adding URL and tooltip to generated layer
Butler, Juan P jpbutler at co.pinellas.fl.us
Tue May 16 18:06:16 EDT 2006
Alain:
Not sure.  The layer is selectable.  I didn't see the addition of
maptips and hyperlinks when creating new layers/markers.  I would like
to create these on the fly along with the markers.  I can create
Property Definitions, but didn't see a documented way to create the
I guess I could use another method of substituting values in a
pre-formed XML layer file.   Just not sure if this is possible to add
maptips/hyperlinks programmatically.
- Juan
From: Alain Lebatard [mailto:alain.lebatard at autodesk.com]
Sent: Tuesday, May 16, 2006 5:50 PM
Subject: RE: [mapguide-users] Adding URL and tooltip to generated layer
Hi Juan,
There is a known problem with maptips/hyperlinks not showing in the AJAX
viewer if the layer is not selectable. Could it  be the same problem
here?
Alain
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Monday, May 15, 2006 1:12 PM
Subject: [mapguide-users] Adding URL and tooltip to generated layer
Hello:
I've got the layer creation pretty much down, but I'm having some issues
with adding the URL and the tooltip info for the markers.   Has anyone
been able to do this?   I left the Tooltip in the XML definition file
for the layer.  I hard coded with a value and it did not come up when
adding the markers to the map.
Any info is appreciated.
- Juan
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060516/c7a6b4f8/attachment.html
More information about the Mapguide_users mailing list
