[mapguide-users] shp or sdf advantages/disadvanatges
Andy Morsell
amorsell at spatialgis.com
Thu May 18 11:09:04 EDT 2006
I have also found that for larger Shape files, converting to SDF at load
time results in much better performance. For large parcel datasets, I also
generalize the data using FME. Since SDF+ contains all of the attribute
information from the source Shape files DBF, you would probably want to just
use that for tooltips, etc. rather than linking to the DBF file. FME from
Safe Software also will soon be including SDF+ support in their product.
The current beta version downloadable from their web site supports SDF+
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
From: shailesh [mailto:shailesh at simplexindia.com]
Sent: Wednesday, May 17, 2006 11:38 PM
Subject: [mapguide-users] shp or sdf advantages/disadvanatges
hi
I am currently using shp files for data resources and some of the data is
above 80 mb
I think it makes the map very slow to load
does converting into sdf or another format help it load faster.
what are advantages /disadvantages .in terms of laoding speed,attribute
table data etc
can i use the convert to sdf option in studio or a there any other
specialized toosl for doing it.
if converted to sdf can i still use the dbf assoicated with shp for tooltips
and attribute data
-shailesh
--------------------------------------------------------------------- To
unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org For additional
commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060518/a307f3af/attachment.html
More information about the Mapguide_users
