[mapguide-users] Access from .Net winforms or console?
Jason Birch Jason.Birch at nanaimo.ca
Mon May 22 18:19:34 EDT 2006
Thanks guys.  Like I said; newbie.  I was trying this on my workstation, which doesn't have MGOS installed.  I had put the rest of the dlls in the bin directory of the console app expecting it to magically work.  Now I have to live with disillusionment. :)
I can see quite a few uses for this application that would not necessarily reside on the web server.  Having to use an external INI file that contains physical paths, etc, is a bit constraining.  It would be great if there was a way to initialize a server connection by specifying host and port (and any other required settings for standard operations) without the need for an external file.
Jason
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Fri 2006-05-19 4:14 PM
Subject: RE: [mapguide-users] Access from .Net winforms or console?
Jason,
I was able to build and run without any problems so I'm with Traian, you
probably need to add C:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\bin to your
path.
Andy
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20060522/64009b0d/attachment.bin
More information about the Mapguide_users mailing list
