[mapguide-users] error running dotnetviewersample
Andy Morsell
amorsell at spatialgis.com
Wed Nov 1 21:32:22 EST 2006
Remove any InitializeSockets() and TerminateSockets() you run across in the
.NET examples and it should then work. They were both removed from the API
definition.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
_____
Sent: Wednesday, November 01, 2006 5:15 PM
Subject: [mapguide-users] error running dotnetviewersample
hi,
i'm running mgos v1.0.2 on win2003 and dotnet 2.0.
from the previous post, i've already do all the necessay steps to run dotnet
sample
-load "Sheboygan.mgp"
-extract "dotnetviewersample", make it run as aplication
-copy all the "bin" folder from "mapviewernet" to "dotnetviewersample"
-copy the "webconfig".ini file on the "www" root to "dotnetviwersample"
but, there seems an error occured, the message error like this, and it
happens bot on win2003+iis6 and win2000+iis5
Compiler Error Message: CS0117: 'MapGuideApi' does not contain a definition
for 'InitializeSockets'
Source Error:
Line 31: try
Line 32: {
Line 33: MapGuideApi.InitializeSockets();
Line 34: InitializeWebTier();
Line 35:
Source File: c:\Program
Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\ajaxview
ersample.aspx Line: 33
how can i fix it?
thankyou
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061101/9a19f207/attachment.html
More information about the Mapguide_users
