[mapguide-users] error running dotnetviewersample
diditho
diditho at kompas.co.id
Wed Nov 1 22:01:27 EST 2006
thankyou, it works like a charm.
better work with vs2005, the intelesense helps a lot...
Andy Morsell wrote:
> Remove any InitializeSockets() and TerminateSockets() you run across
> in the .NET examples and it should then work. They were both removed
> from the API definition.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> *From:* diditho [mailto:diditho at kompas.co.id]
> *Sent:* Wednesday, November 01, 2006 5:15 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] error running dotnetviewersample
> hi,
> i'm running mgos v1.0.2 on win2003 and dotnet 2.0.
> from the previous post, i've already do all the necessay steps to run
> dotnet sample
> -load "Sheboygan.mgp"
> -extract "dotnetviewersample", make it run as aplication
> -copy all the "bin" folder from "mapviewernet" to "dotnetviewersample"
> -copy the "webconfig".ini file on the "www" root to "dotnetviwersample"
> but, there seems an error occured, the message error like this, and it
> happens bot on win2003+iis6 and win2000+iis5
> *Compiler Error Message: *CS0117: 'MapGuideApi' does not contain a
> definition for 'InitializeSockets'
> *Source Error:
> Line 31: try
> Line 32: {
> Line 33: MapGuideApi.InitializeSockets();
> Line 34: InitializeWebTier();
> Line 35:
> *Source File:* c:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\dotnetviewersample\ajaxviewersample.aspx
> *Line:* 33
> how can i fix it?
> thankyou
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061102/9438dc11/attachment.html
More information about the Mapguide_users
