[mapguide-users] Permissions problem...
Andrew DeMerchant andrew.demerchant at gemtec.ca
Tue Nov 7 12:28:45 EST 2006
Ya, that's sort of what I figured was happening....that it's not asking
me to log in, because it doesn't have permission to ask...which is a bit
silly. If that's the case, then it's a fairly annoying bug....
Andrew
Walt Welton-Lair wrote:
> So it's a question of order.  Should MapGuide first authenticate
> before it tries to access the resource (and find out that you don't
> have permission)?  It looks like it does it the other way - it checks
> whether you have permission before authenticating.  I don't know the
> right answer.
> I do know that the DWF Viewer code which handles the HTTP request
> knows nothing about MapGuide and doesn't know what to do with the
> permission denied response.
> Walt
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Tuesday, November 07, 2006 6:15 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* Re: [mapguide-users] Permissions problem...
> Ah...sorry. I should have posted the error that it gives me.....When I
> try to use the DWF Viewer, this is what I get:
> Permission denied to resource: Library://test/
> Permission denied to resource: Library://test/ Exception occurred in
> method MgResourceHeaderManager.CheckPermission at line 2495 in file
> c:\build_tux_area\mgdev_opensource\server\src\services\resource\ResourceHeaderManager.cpp
> Andrew
>> So DWF Viewer doesn't prompt for credentials.  Do you get back any
>> data or does it just sit there?
>> Ultimately DWF Viewer simply makes a Mapping Service GetMap HTTP
>> request via WinINet.  It prompts for credentials when it gets a 401
>> response to that initial request, and then resubmits the GetMap
>> request.  If it just sits there that means it didn't get a 401
>> response and it thinks it's done.
>> Walt
>> *Sent:* Tuesday, November 07, 2006 4:53 PM
>> *Subject:* [mapguide-users] Permissions problem...
>> I've got a project that I want to password protect....I've given a
>> specific MapGuide User read permissions to my library (removed
>> 'Everyone', and added 'Administrator' as read/write as well). What's
>> happening now is that the DWF viewer isn't asking me to log in. If I
>> change my URL to use the AJAX viewer, it works fine (asks me to log
>> in, and then works as it should). So, for example:
>> http://host/mapguide/mapviewerdwf/?WEBLAYOUT=.....   ----This does
>> NOT work
>> http://host/mapguide/mapviewerajax/?WEBLAYOUT=.....   ----This DOES work
>> This happens on any PC that I've tested it on. Am I missing something
>> here, or is this a bug? I'm using v1.0.2.17861 (the latest release).
>> Andrew
>> 	*Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
> 	*Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users mailing list
