[mapguide-users] ODBC problem...
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue Nov 7 14:41:03 EST 2006
Sadly, no....I've even tried reversing them, incase the FDO was
backwards for some reason. But I can't even see anything in the Layer
preview....which should mean that it's a bigger problem than just
swapped coords.
James: With the previous ODBC FDO, I did have my points showing
up....but I do remember that as soon as I tried to do a join, my points
vanished. I'd bet that if you removed your join, your maps wouldn't be
empty any more. My work around has been to simply abandon the ODBC FDO
until it gets to a point at which it's usable.....I had thought that
maybe it was there by now, but it's looking like it's not quite there yet.
Andrew
Jason Birch wrote:
> You're not mixing up X and Y? ;)
> I haven't tried this provider myself yet...
> *From:* Andrew DeMerchant
> *Sent:* Tuesday, November 07, 2006 11:21
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] ODBC problem...
> Ok, so I decided to give the ODBC FDO another chance...to see if it's
> any faster / better now than it was back in v1.0....It does seems to
> be a bit better, only I can't seem to get it to work completely.
> I can see the list of my tables...I can pick my geometry fields, etc.
> But I can't seem to get it to actually work. Either it's not reading
> my X and Y columns, or else it's reading them, but discarding the data
> for some reason....When I preview my layer, I see nothing. I've tried
> everything that I can think of...I've tried changing the field type
> (double, single, integer), I've tried various coord systems, I even
> tried deleting all records in my table that have empty X / Y
> fields.......Anyone have a solution? I've looked at the FDO docs, but
> don't see anything that can help me.
> Andrew
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-2GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide_users
