[mapguide-users] A question regarding MGE Studio and DWF
Gary Morin
gary.morin at keygis.co.uk
Wed Nov 8 08:52:17 EST 2006
HI Chris
I will read through the install documentation again to see I can spot
anything. But it was a standard MGE installed all directories and virtual
directories created were created by the install automatically.
Thanks
Gary
> -----Original Message-----
> From: Chris White [mailto:chris.white at keytraffic.com]
> Sent: 08 November 2006 13:18
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] A question regarding MGE Studio and DWF
> Gary,
> It is probably worth you comparing the settings for the mapviewerajax
> and mapviewerdwf directories, as Ajax works fine I would have thought it
> was something to do with the way you have set it up. Full details can be
> found in the Installing and Configuring on Windows document.
> Cheers,
> Chris
> From: Gary Morin [mailto:gary.morin at keygis.co.uk]
> Sent: 08 November 2006 13:06
> Bump
> Any suggestions from anyone will be much appricated
> Thanks
> > Hi
> > Sorry for the delay in given feed back, the challenge dialog box is
> > definitely Mapguide.
> > Pressing preview in AJAX the challenge dialog box is display you enter
> you
> > details and it works, for DWF it just keeps showing the challenge
> dialog
> > box.
> > If I press cancel I get:
> > Failed to open URL: status code 401 Unauthorised
> > Any help will be much appreciated.
> > Cheers
> > Gary
> > > From: Dave Wilson [mailto:dave.wilson at autodesk.com]
> > > Sent: 03 November 2006 23:09
> DWF
> > > Within IIS,
> > > check the Directory Security tab. Edit the Anonymous user settings
> and
> > > ensure Integrated Windows Authentication is disabled. This may be
> > > causing some grief. The credentials popup you get should be for MG
> > > Enterprise, not your machine login.
> > > Regards,
> > > Dave
> > > Sent: Friday, November 03, 2006 11:20 AM
> > > Subject: [mapguide-users] A question regarding MGE Studio and DWF
> > > Hi
> > > I'm just starting to use MG Enterprise, I had major problem on old
> > > machine and it now working(ish)on new PC.
> > > I have a question regarding studio security.
> > > I'm using MGE on local machine XP pro with IIS and ASP.NET
> > > When I view a preview using AJAX I prompted to enter user and
> password,
> > > which I do with standard values, Administrator etc and it works
> fine.
> > > But when I try with DWF preview it won't accept the credentials, I
> just
> > > can't get in to view, can someone help me out.
> > > Thanks
> > > Gary
> > > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > For additional commands, e-mail: users-help at mapguide.osgeo.org
> ______________________________________________________________________
> This email has been scanned by the MessageLabs Email Security System.
> For more information please visit http://www.messagelabs.com/email
More information about the Mapguide_users
