[mapguide-users] A question regarding MGE Studio and DWF
Chris White
chris.white at keytraffic.com
Wed Nov 8 08:57:41 EST 2006
Gary,
You would have thought that they would be correct but I've found that it
does not always set everything up correctly! It particularly seems to
have problems setting the .Net version to user...
Cheers,
Chris
-----Original Message-----
From: Gary Morin [mailto:gary.morin at keygis.co.uk]
Sent: 08 November 2006 13:52
Subject: RE: [mapguide-users] A question regarding MGE Studio and DWF
HI Chris
I will read through the install documentation again to see I can spot
anything. But it was a standard MGE installed all directories and
virtual
directories created were created by the install automatically.
Thanks
Gary
> From: Chris White [mailto:chris.white at keytraffic.com]
> Sent: 08 November 2006 13:18
> Gary,
> It is probably worth you comparing the settings for the mapviewerajax
> and mapviewerdwf directories, as Ajax works fine I would have thought
it
> was something to do with the way you have set it up. Full details can
be
> found in the Installing and Configuring on Windows document.
> Cheers,
> Chris
> Sent: 08 November 2006 13:06
> Bump
> Any suggestions from anyone will be much appricated
> Thanks
> > Hi
> > Sorry for the delay in given feed back, the challenge dialog box is
> > definitely Mapguide.
> > Pressing preview in AJAX the challenge dialog box is display you
enter
> you
> > details and it works, for DWF it just keeps showing the challenge
> dialog
> > box.
> > If I press cancel I get:
> > Failed to open URL: status code 401 Unauthorised
> > Any help will be much appreciated.
> > Cheers
> > Gary
> > > From: Dave Wilson [mailto:dave.wilson at autodesk.com]
> > > Sent: 03 November 2006 23:09
> DWF
> > > Within IIS,
> > > check the Directory Security tab. Edit the Anonymous user settings
> and
> > > ensure Integrated Windows Authentication is disabled. This may be
> > > causing some grief. The credentials popup you get should be for MG
> > > Enterprise, not your machine login.
> > > Regards,
> > > Dave
> > > Sent: Friday, November 03, 2006 11:20 AM
> > > Subject: [mapguide-users] A question regarding MGE Studio and DWF
> > > Hi
> > > I'm just starting to use MG Enterprise, I had major problem on old
> > > machine and it now working(ish)on new PC.
> > > I have a question regarding studio security.
> > > I'm using MGE on local machine XP pro with IIS and ASP.NET
> > > When I view a preview using AJAX I prompted to enter user and
> password,
> > > which I do with standard values, Administrator etc and it works
> fine.
> > > But when I try with DWF preview it won't accept the credentials, I
> just
> > > can't get in to view, can someone help me out.
> > > Thanks
> > > Gary
> > > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > For additional commands, e-mail: users-help at mapguide.osgeo.org
> ______________________________________________________________________
> This email has been scanned by the MessageLabs Email Security System.
> For more information please visit http://www.messagelabs.com/email
More information about the Mapguide_users
