[mapguide-users] errors building FDO 3.1.0_R071a
Eduardo Patto Kanegae epk.lists at gmail.com
Sat Nov 11 14:21:23 EST 2006
Thanks Jack, that works.
But now I got:
CommonTest.cpp:301: error: converting to execution character set: Invalid or
incomplete multibyte or wide character
make[2]: *** [CommonTest.o] Error 1
make[2]: Leaving directory `/usr/src/webmapit/mapguide-1.0.2
/OpenSource_FDO/fdo/unit_test'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/webmapit/mapguide-1.0.2
/OpenSource_FDO/fdo'
make: *** [all-recursive] Error 1
Eduardo
On 10/30/06, Jack Lee <jack.lee at autodesk.com> wrote:
>  Hi Eduardo,
> You should remove FdoIRasterPropertyDictionary:: from the file
> IRasterPropertyDictionary.h.
> *From:* Eduardo Patto Kanegae [mailto:epk.lists at gmail.com]
> *Sent:* Monday, October 30, 2006 6:04 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] errors building FDO 3.1.0_R071a
> Hi,
> I'm on Fedora 5( GCC 4) and can't build FDO.
> It gives me this errors:
> .deps/GisSpatialEnvelope.Tpo -c GisSpatialEnvelope.cpp  -fPIC -DPIC -o
> .libs/GisSpatialEnvelope.o
> ../../inc/fdo/Raster/IRasterPropertyDictionary.h:64: error: extra
> qualification 'FdoIRasterPropertyDictionary::' on member
> 'GetPropertyDataType'
> ../../inc/fdo/Raster/IRasterPropertyDictionary.h:75: error: extra
> qualification 'FdoIRasterPropertyDictionary::' on member 'GetProperty'
> ../../inc/fdo/Raster/IRasterPropertyDictionary.h:85: error: extra
> qualification 'FdoIRasterPropertyDictionary::' on member 'SetProperty'
> ../../inc/fdo/Raster/IRasterPropertyDictionary.h:96: error: extra
> 'GetPropertyDefault'
> ../../inc/fdo/Raster/IRasterPropertyDictionary.h:107: error: extra
> 'IsPropertyRequired'
> ../../inc/fdo/Raster/IRasterPropertyDictionary.h:119: error: extra
> 'IsPropertyEnumerable'
> ../../inc/fdo/Raster/IRasterPropertyDictionary.h:131: error: extra
> qualification 'FdoIRasterPropertyDictionary::' on member 'GetPropertyValues'
> ../../inc/fdo/Raster/IRasterPropertyDictionary.h:146: error: extra
> qualification 'FdoIRasterPropertyDictionary::' on member 'SetPropertyValues'
> make[4]: *** [GisSpatialEnvelope.lo] Error 1
> make[4]: Leaving directory `/usr/src/webmapit/mapguide-1.0.2
> /OpenSource_FDO/fdo/Unmanaged/src/spatial'
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory `/usr/src/webmapit/mapguide-1.0.2
> /OpenSource_FDO/fdo/Unmanaged/src'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/usr/src/webmapit/mapguide- 1.0.2
> /OpenSource_FDO/fdo/Unmanaged'
> I also tried GCC 3.2 and got the same error.
> is there any deps not documented in install instructions?
> best
> http://www.webmapit.com.br
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061111/a89f4099/attachment.html
More information about the Mapguide_users mailing list
