[mapguide-users] MySQL FDO and Fedora 4
Tom Fukushima tom.fukushima at autodesk.com
Mon Nov 13 18:27:50 EST 2006
Hi Jason,
MapGuide 1.0.2 compiles with FDO 3.1, the trunk currently compiles with
FDO 3.2.  They need to be compiled against the correct version as the
APIs are different. You will get compilation errors otherwise.  You do
not need to recompile FDO everytime MapGuide is compiled; you should
only need to recompile FDO if you update the source for it or update one
of the dependent components of it (such as the MySQL client).
Hope this helps,
Tom
  _____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Saturday, November 11, 2006 2:24 AM
Subject: RE: [mapguide-users] MySQL FDO and Fedora 4
Hi Tom,
So, does MapGuide need to be compiled against the same revision of FDO
that it runs with?  I've often wondered if I need to recompile FDO every
time I recompile MapGuide just to keep them in sync.  I guess if the
interface is stable I may not need to keep up with FDO?
Jason
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061113/e9cdba8d/attachment.html
More information about the Mapguide_users mailing list
