[mapguide-users] RE: Studio Enterprise and Web Studio Cannot Connect Randomly
Chris Gountanis cgountanis at mpower-tech.com
Wed Nov 15 14:20:26 EST 2006
I used this as a .bat batch file. Also worked as far as I know. Might have
to double check your AdminScripts are still there.
cscript //h:cscript
C:\Inetpub\AdminScripts\adsutil set w3svc/MaxConnections 40
pause
Chris
-----Original Message-----
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, November 15, 2006 1:12 PM
Subject: RE: [mapguide-users] RE: Studio Enterprise and Web Studio Cannot
Connect Randomly
To increase the XP IIS connection limit from 10 to 40 (which has worked fine
on my development laptop), see this page at the MGOS Wiki.
http://wiki.osgeo.org/index.php/MapGuide_Open_User_Technical_FAQ%27s
Andy
From: Trevor Wekel [mailto:trevor.wekel at autodesk.com]
Sent: Wednesday, November 15, 2006 11:04 AM
To: Chris Gountanis; users at mapguide.osgeo.org
Subject: [mapguide-users] RE: Studio Enterprise and Web Studio Cannot
Connect Randomly
Hi Chris,
IIS under Windows XP has a hard coded concurrent connection limit - 10
connections I think.  Internet Explorer and the embedded  IE control within
Studio may spin up that many connections to serve a map.  If you get back a
bunch of 403 errors then you are probably hitting this limit.
There is also an occassional cannot connect to URL error when a FastCGI
Mapagent process has shutdown and another one has not started up yet.
Typically, this is a single error.  The error "wakes up the agent" and a
second connection attempt should go through successfully.
I have also seen rare cases where the Apache/IIS FastCGI link to
Mapagent.exe and php-cgi.exe does not initialize successfully.  This
effectively locks out the Web Extensions.  In these cases stopping Apache or
IIS, manually killing all of the mapagent.exe and php-cgi.exe process, and
restarting Apache or IIS generally corrects the problem.  As an added
measure of insurance, stopping and restarting MapGuide Server can be
performed along with the Apache/IIS restart.
Hopefully this will help,
Trevor
From: Chris Gountanis [mailto:cgountanis at mpower-tech.com]
Sent: Tuesday, November 14, 2006 9:48 AM
Subject: Studio Enterprise and Web Studio Cannot Connect Randomly
Randomly, I have noticed that Studio Enterprise gives errors like cannot
connect to URL. Web Studio bombs and spits out a whole message box with page
code... basically same error. I have fixed the issue with a reboot and
sometimes a uninstall/reinstall of the extensions. Using IIS/PHP
installation options on XP as my development and testing machine. Why does
this happen?
Chris
More information about the Mapguide_users mailing list
