USE PRINT LAYOUT CODE
    BradM
    masonb at dfo-mpo.gc.ca
    Mon Nov 20 11:56:15 EST 2006
If you have a moment, could you help find the code for using the
print layout function when plotting to DWF? We are using MGE.
We can plot to DWF ok but we cannot use the function "use print layout".
This function creates a nice legend in the dwf.
Here is the error we get.
Resource was not found: Library://SGI_Print_Layout.PrintLayout
Resource was not found: Library://SGI_Print_Layout.PrintLayout Exception
occurred in method MgResourceDefinitionManager.GetDocument at line 476 in
file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionManag
er.cpp
thanks!
View this message in context: http://www.nabble.com/USE-PRINT-LAYOUT-CODE-tf2670252.html#a7446015
More information about the Mapguide_users
