[mapguide-users] USE PRINT LAYOUT CODE
Walt Welton-Lair
walt.welton-lair at autodesk.com
Mon Nov 20 12:09:51 EST 2006
Have you created the necessary print layout resource? I know MapGuide
Studio lets you create them using an XML editor.
-----Original Message-----
Sent: Monday, November 20, 2006 5:56 PM
Subject: [mapguide-users] USE PRINT LAYOUT CODE
If you have a moment, could you help find the code for using the
print layout function when plotting to DWF? We are using MGE.
We can plot to DWF ok but we cannot use the function "use print layout".
This function creates a nice legend in the dwf.
Here is the error we get.
Resource was not found: Library://SGI_Print_Layout.PrintLayout
Resource was not found: Library://SGI_Print_Layout.PrintLayout Exception
occurred in method MgResourceDefinitionManager.GetDocument at line 476
in
file
c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionM
anag
er.cpp
thanks!
View this message in context:
http://www.nabble.com/USE-PRINT-LAYOUT-CODE-tf2670252.html#a7446015
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users
