USE PRINT LAYOUT CODE
Joy Appler
jappler at my.bcit.ca
Mon Nov 20 12:41:25 EST 2006
I belive we have created the necessary print layout resource by creating it
in MGE Studio, and referencing it in the following lines of php code:
$layout = null;
if (array_key_exists('UseLayout', $_GET) && $_GET['UseLayout'] == 'true')
$layoutRes = new
MgResourceIdentifier("Library://SGI_Print_Layout.PrintLayout");
$layout = new MgLayout($layoutRes, "gulfIslandsAlbersMap",
MgPageUnitsType::Inches);
Do you think this is done wrong?
Walt Welton-Lair wrote:
> Have you created the necessary print layout resource? I know MapGuide
> Studio lets you create them using an XML editor.
> -----Original Message-----
> From: BradM [mailto:masonb at dfo-mpo.gc.ca]
> Sent: Monday, November 20, 2006 5:56 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] USE PRINT LAYOUT CODE
> If you have a moment, could you help find the code for using the
> print layout function when plotting to DWF? We are using MGE.
> We can plot to DWF ok but we cannot use the function "use print layout".
> This function creates a nice legend in the dwf.
> Here is the error we get.
> Resource was not found: Library://SGI_Print_Layout.PrintLayout
> Resource was not found: Library://SGI_Print_Layout.PrintLayout Exception
> occurred in method MgResourceDefinitionManager.GetDocument at line 476
> in
> file
> c:\build_tux_area\mgdev\server\src\services\resource\ResourceDefinitionM
> anag
> er.cpp
> thanks!
> http://www.nabble.com/USE-PRINT-LAYOUT-CODE-tf2670252.html#a7446015
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/USE-PRINT-LAYOUT-CODE-tf2670252.html#a7446818
More information about the Mapguide_users
