[mapguide-users] code of Update/delete/insert of Features source.
Farah farah at egovernments.org
Wed Nov 29 01:07:56 EST 2006
Hi..
Here is a sample code to update features in a temporary layer. It creates an
MgUpdateFeatures command , by passing to it a propertycollection that
defines the properties to be changed and a filter that specifies which
features need to be updated.
	MgMap map = new MgMap();
	map.Open(resourceService, "schoolMap");
	MgLayer parcelMarkerLayer = GetLayerByName(map, "SchoolMarker");
	if (parcelMarkerLayer!=null)
		//Make the required organisation blue
		filter = "SCHOOL_ID = " + schoolId ;
	       MgFeatureCommandCollection blueMarkerCommands = new
MgFeatureCommandCollection();
		MgPropertyCollection properties = new
MgPropertyCollection();
		int selected = 1;
		properties.Add(new MgInt32Property("SELECTED", selected));
		MgUpdateFeatures updateCommand = new
MgUpdateFeatures("SchoolMarker", properties, filter);
		blueMarkerCommands.Add(updateCommand);
		//execute blue marker command
		if (blueMarkerCommands.GetCount() >=1 )
ReleaseReader(featureService.UpdateFeatures(layerFeatureResource,
blueMarkerCommands, false), blueMarkerCommands);
		parcelMarkerLayer.SetVisible(true);
		parcelMarkerLayer.ForceRefresh();
		map.Save(resourceService);
		mapUpdated = true;
void ReleaseReader(MgPropertyCollection res, MgFeatureCommandCollection
commands) throws MgException
    if(res == null)
        return;
    for(int i = 0; i < res.GetCount(); i++)
        MgFeatureCommand cmd = commands.GetItem(i);
        if(cmd instanceof MgInsertFeatures)
            MgFeatureProperty resProp = (MgFeatureProperty)res.GetItem(i);
            if(resProp != null)
                MgFeatureReader reader =
(MgFeatureReader)resProp.GetValue();
                if(reader == null)
                    return;
                reader.Close();
Regards
Farah
-----Original Message-----
From: Maciej Skorczewski [mailto:maciej.skorczewski at procad.pl]
Sent: Tuesday, November 28, 2006 8:29 PM
Subject: [mapguide-users] code of Update/delete/insert of Features source.
  hi all!
did anybody can send code of  Update/delete/insert Features in *.sdf
i am looking example of code.
...all example show code of select.
thx.
maciek
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide_users mailing list
