[mapguide-users] ArcSDE FDO provider
Haris Kurtagic
haris at sl-king.com
Mon Oct 2 14:52:35 EDT 2006
Yes, I understand that you need to be cautious.
I would like to hear more about your issues.
You can contact me on my email haris at sl-king.com. I suppose it is too
much for this list
Haris
Sent: Monday, October 02, 2006 8:47 PM
Subject: RE: [mapguide-users] ArcSDE FDO provider
Thanks Haris,
I am still in the planning stage. Not wanting to rush into any more
problems I can't get out of easily. I had pretty much hung my hat on
oracle sdo when I discovered that the esri implementation doesn't really
support all metadata categories. So now the sde-fdo seems to be a
cleaner easier solution. And as of yet I haven't found anyone who can
convince me that esri will fix the inadequacies. (9.2 maybe not.) So
even though we are talking about oracle sdo 10.2.0.1 spatial data, I
really have an esri version of that. It does not contain the wkt (SRID)
value, the min, max bounding values or the tolerance. These values
cannot just be inserted because then sde loses object control of the
tables.
Probably more ranting than you want to hear. If you have further
interest let me know I can fill your ear.
Brad
When these values are present in dbtune file the entities are created as
sdo objects that have correct metadata. But if you do arcgis doesn't
respond as expected.
##DEFAULTS
SDO_LB_2 -140000.000000
SDO_TOLERANCE_2 0.000000500000
SDO_VERIFY "FALSE"
SDO_UB_2 430000.000000
SDO_UB_1 2300000.000000
SDO_TOLERANCE_1 0.000000500000
SDO_LB_1 1849000.000000
ATTRIBUTE_BINARY "LONGRAW"
SDO_SRID 41106
SDO_DIMNAME_2 "y"
SDO_DIMNAME_1 "x"
GEOMETRY_STORAGE "SDO_GEOMETRY
Sent: Monday, October 02, 2006 12:57 PM
One option for displaying SDO_GEOMETRY from Oracle 10.2 ( and others) is
to use King.Oracle provider.
It is not yet under fdooracle subproject but binaries you can get here
www.sl-king.com/fdooracle.
Haris
Sent: Monday, October 02, 2006 7:48 PM
Subject: [mapguide-users] ArcSDE FDO provider
As there is no discussion or mailing list for the arcsde fdo provider,
and the oracle fdo only has the commits list available... I would like
to ask a question here.
Q I am running Oracle 10.2.0.1 database. Using oracle sdo_geometry as my
sde (10g) datatype. It would seem at first glance that I have several
options for display in mapguide server. However I notice that the arcsde
fdo specifically states 9.2.0.6 Of my two oracle installations neither
has that specific version (9.2.0.5 and 10.2.0.1). Will this restriction
be rectified? Oracle version jumping is not a walk in the park, and I
wouldn't consider it in the hopes that it might work and there might be
a new version next month that would support only one more version jump.
ygtp
Not that I want to reconsider but can someone enlighten me on the many
options. What the pros and cons of each are and what an industry trend
may be in the near future?
GML
OGR
SVG
SDO
BTW there is an sde 9.1 for 10g
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061002/61090eeb/attachment.html
More information about the Mapguide_users
