mapguide install on FC4.
Nick Sadowy
nick at cd-data.com
Mon Oct 2 18:23:00 EDT 2006
Hi All.
I am having a heck of a time getting mapguide to compile all the way through. I have been able to overcome some hurdles by making the individual packages that failed, but I haven't had any luck getting over this latest issue:
During the make, I am getting the following error:
Making all in Service
make[2]: Entering directory `/usr/local/src/mapguide-1.0.1/Common/Service'
/bin/sh ../../libtool --tag=CXX --mode=link g++ -O2 -g -pipe -march=i386 -mcpu=i686 -fno-use-cxa-atexit -fexceptions -o libMgCommon.la -rpath /usr/local/mapguideopensource/lib -version-info 7:0:0 -L../../Oem/dbxml-2.2.13/install/lib -L../../Common/CoordinateSystem ServiceControllerBuild.lo ServiceCoordinateSystemBuild.lo ServiceDataBuild.lo ServiceExceptionBuild.lo ServiceGeometryBuild.lo ServiceMapLayerBuild.lo ServiceNetBuild.lo ServiceServicesBuild.lo ServiceSystemBuild.lo ServiceUtilBuild.lo -lxerces-c -lMgCoordinateSystem ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a ../Security/libMgSecurity.a
*** Warning: Linking the shared library libMgCommon.la against the
*** static library ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a is not portable!
*** static library ../Security/libMgSecurity.a is not portable!
g++ -shared -nostdlib /usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crti.o /usr/lib/gcc/i386-redhat-linux/4.0.0/crtbeginS.o .libs/ServiceControllerBuild.o .libs/ServiceCoordinateSystemBuild.o .libs/ServiceDataBuild.o .libs/ServiceExceptionBuild.o .libs/ServiceGeometryBuild.o .libs/ServiceMapLayerBuild.o .libs/ServiceNetBuild.o .libs/ServiceServicesBuild.o .libs/ServiceSystemBuild.o .libs/ServiceUtilBuild.o -L/usr/local/src/mapguide-1.0.1/Oem/dbxml-2.2.13/install/lib -lxerces-c -lMgCoordinateSystem ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a ../Security/libMgSecurity.a -L/usr/lib/gcc/i386-redhat-linux/4.0.0 -L/usr/lib/gcc/i386-redhat-linux/4.0.0/../../.. -lstdc++ -lm -lc -lgcc_s /usr/lib/gcc/i386-redhat-linux/4.0.0/crtendS.o /usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crtn.o -march=i386 -mcpu=i686 -Wl,-soname -Wl,libMgCommon.so.7 -o .libs/libMgCommon.so.7.0.0/usr/bin/ld: cannot find -lMgCoordinateSystem
collect2: ld returned 1 exit status
make[2]: *** [libMgCommon.la] Error 1
make[2]: Leaving directory `/usr/local/src/mapguide-1.0.1/Common/Service'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/src/mapguide-1.0.1/Common'
make: *** [all-recursive] Error 1
[root at user2 mapguide-1.0.1]#
Is it normal to have all these problems getting mapguide Open Source up and running? I am on a clean build of Fedora Core 4.
Thank you in advance.
Nick
Nicholas Sadowy
Sr. Information Manager
CD-Data, Inc.
2330 E. Bidwell St, Suite 200
Folsom, CA 95630
(916) 817-2211 x106
nick at cd-data.com
http://www.cd-data.com
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061002/268e8e01/attachment.html
More information about the Mapguide_users
