[mapguide-users] mapguide install on FC4.
alba a.penitente at gepaspa.com
Tue Oct 3 02:52:20 EDT 2006
Hi Nick
also I had the same problems, but I have installed gcc 4.0.2 and not gcc
4.0.0 of FC4.
now would want to ask I one what you?
which are the steps that you have executed in order to install FDO 3.1  and
to make the date test?
thank you
Alba
Nick Sadowy wrote:
> Hi All.
> I am having a heck of a time getting mapguide to compile all the way
> through.  I have been able to overcome some hurdles by making the
> individual packages that failed, but I haven't had any luck getting over
> this latest issue:
> During the make, I am getting the following error:
> Making all in Service
> make[2]: Entering directory `/usr/local/src/mapguide-1.0.1/Common/Service'
> /bin/sh ../../libtool --tag=CXX --mode=link g++  -O2 -g -pipe -march=i386
> -mcpu=i686 -fno-use-cxa-atexit -fexceptions   -o libMgCommon.la -rpath
> /usr/local/mapguideopensource/lib -version-info 7:0:0
> -L../../Oem/dbxml-2.2.13/install/lib -L../../Common/CoordinateSystem
> ServiceControllerBuild.lo ServiceCoordinateSystemBuild.lo
> ServiceDataBuild.lo ServiceExceptionBuild.lo ServiceGeometryBuild.lo
> ServiceMapLayerBuild.lo ServiceNetBuild.lo ServiceServicesBuild.lo
> ServiceSystemBuild.lo ServiceUtilBuild.lo -lxerces-c -lMgCoordinateSystem
> ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a
> ../Security/libMgSecurity.a
> *** Warning: Linking the shared library libMgCommon.la against the
> *** static library ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a is not
> portable!
> *** static library ../Security/libMgSecurity.a is not portable!
> g++ -shared -nostdlib /usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crti.o
> /usr/lib/gcc/i386-redhat-linux/4.0.0/crtbeginS.o
> .libs/ServiceControllerBuild.o .libs/ServiceCoordinateSystemBuild.o
> .libs/ServiceDataBuild.o .libs/ServiceExceptionBuild.o
> .libs/ServiceGeometryBuild.o .libs/ServiceMapLayerBuild.o
> .libs/ServiceNetBuild.o .libs/ServiceServicesBuild.o
> .libs/ServiceSystemBuild.o .libs/ServiceUtilBuild.o
> -L/usr/local/src/mapguide-1.0.1/Oem/dbxml-2.2.13/install/lib -lxerces-c
> -lMgCoordinateSystem ../../Oem/geos-2.2.0/source/geom/.libs/libgeos.a
> ../Security/libMgSecurity.a -L/usr/lib/gcc/i386-redhat-linux/4.0.0
> -L/usr/lib/gcc/i386-redhat-linux/4.0.0/../../.. -lstdc++ -lm -lc -lgcc_s
> /usr/lib/gcc/i386-redhat-linux/4.0.0/crtendS.o
> /usr/lib/gcc/i386-redhat-linux/4.0.0/../../../crtn.o  -march=i386
> -mcpu=i686 -Wl,-soname -Wl,libMgCommon.so.7 -o
> .libs/libMgCommon.so.7.0.0/usr/bin/ld: cannot find -lMgCoordinateSystem
> collect2: ld returned 1 exit status
> make[2]: *** [libMgCommon.la] Error 1
> make[2]: Leaving directory `/usr/local/src/mapguide-1.0.1/Common/Service'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/local/src/mapguide-1.0.1/Common'
> make: *** [all-recursive] Error 1
> [root at user2 mapguide-1.0.1]#
> Is it normal to have all these problems getting mapguide Open Source up
> and running?  I am on a clean build of Fedora Core 4.
> Thank you in advance.
> Nick
> Nicholas Sadowy
> Sr. Information Manager
> CD-Data, Inc.
> 2330 E. Bidwell St, Suite 200
> Folsom, CA 95630
> (916) 817-2211 x106
> nick at cd-data.com
> http://www.cd-data.com
View this message in context: http://www.nabble.com/mapguide-install-on-FC4.-tf2372882.html#a6615146
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide_users mailing list
