[mapguide-users] SQL Server 2005
Warren Medernach warren.medernach at imaginit.ca
Thu Oct 5 14:41:42 EDT 2006
Hi Brad,
That was the case in Map 2006 and pushing the features into an Oracle
datastore through a Feature Source connection, but I don't think it's
possible (right now) to push the Classified objects to the FDO
datastore?
I would like nothing more than to be incorrect on this, so please let me
know if I am missing something!
Thanks
   Warren Medernach
   IMAGINiT Professional Services
Sent: Thursday, October 05, 2006 12:22 PM
Subject: RE: [mapguide-users] SQL Server 2005
If I'm not mistaken, you can also create feature classes and apply those
to your objects. Once the objects are classified then there use to be an
option to load that directly to a connection. I'll take a look and see
if this is still true.
Brad
From: Warren Medernach [mailto:warren.medernach at imaginit.ca]
Sent: Thursday, October 05, 2006 9:30 AM
Hello Keith,
The basic process is as follows:
    - Create the datastore using the FdoUserManager.exe found in the
<Map Install>\FDO\Bin folder
    - Create a user for this datastore using the same tool above.
As for getting data into the store...  this is the tricky part as there
are no direct tools in Map to get dwg data into the datastore.  Once
connected, you could define the schema manually and populate it manually
in Map.  However one method I have employed for getting data into the
datastore is to export the dwg data as SHP (yes I know there are
inherent problems with this method...  i.e. Arcs), and then connecting
to that SHP file, and then performing a Bulk Copy from the SHP to the SS
Datastore.  This method has worked pretty well to populate the SS
datastore.
Hope this helps.
   Warren Medernach
From: Campbell, Keith A [mailto:keith.campbell at atkinsglobal.com]
Sent: Thursday, October 05, 2006 3:22 AM
Robert,
>From what I can see, the documentation that comes with Map 2007 is
somewhat lacking when it comes to detailing how data, including the
geometry, can be put into SQL Server. E.g. do we need a blank database
on the SQL instance? Can you point me to any documentation?
Keith
From: Robert Fortin [mailto:robert.fortin at autodesk.com]
Sent: 04 October 2006 18:03
Jim,
The AGF is a legacy name valid until FDO 3.1 that is showing in the doc.
Although it still show up in the doc, it has been replaced by FGF (FDO
Geometry Format) for API function and class names in FDO 3.2    e.g.
GisAgfGeometryFactory became FdoFgfGeometryFactory
Look into the FDG_FDODevGuide.pdf under "The Geometry API". It describes
the binary format.
There is an API to simplifies reading/wrting binary AGF.
There is also a text version AGF text (search AGF Text).
RF
From: Lockyer James [mailto:James.Lockyer at bradford.nhs.uk]
Sent: Wednesday, October 04, 2006 11:37 AM
Hi Robert
Thanks for that, I read some of the documents but none stated that the
FDO SQL only worked if you had Map 3D - it was something I guessed by
accident when I was trying to reverse engineer the process of
connection.  So effective FDO to me would mean one that didn't rely on
me purchasing a third software package.
What information is there about FGF binary format? I've managed to
create an SQL file which sorts out the meta data on the SQL file.  I'd
stopped when I established that the expected datasource was in fact
binary rather than GML (which was my firt thought as to how data could
be stored).
Jim
Sent: Wed 04/10/2006 15:59
Jim,
I guess as for the documentation, it is an oversight and should be
fixed.  Some of this documentation exist from the FDO side
(FDG_FDODevGuide.pdf and FET_TheEssentialFDO.pdf available on the open
source side)   But I agree that even there there is not enough and could
be further refine.
Mapguide SP1 will introduce performance enhancement for reading data.  I
hope that it will cover some of your concern with your Odbc case.
"And is there any intention of creating an effective FDO for SQL."
I'm not sure what you would consider an effective provider for SQL
server.  SQL Server doesn't have native support for geometry.
Therefore, we need some mechanism to deal with it.  Like I said, you can
still read data out of SQL server but that has limited use if you can't
get your geometry out of it.  The geometry is currently stored in FGF
binary format and the database requires FDO metadata in order to work
with geometry.
We look at supporting geometry stored in OGC WKT format to give some
flexibility for non-FDO enable database but it is not currently
implemented at this time.
RF
Sent: Wednesday, October 04, 2006 10:09 AM
Cheers,
Can I ask why it has taken three months to point that out or why this is
not mentioned in the any of the help files/ published material on the
internet or for that matter why the UK resellers are unaware of this
fact.  And is there any intention of creating an effective FDO for SQL.
In case you have X,Y,Z coordinates stored in different columns, the ODBC
provider should be used against SQL Server data. - has this been speeded
up in the latest release?  As when I tried this it took over 40 minutes
to map out four points.
Has anyone thought about using GML as a storage mechanism?
Jim
James Lockyer
GIS Specialist
IM&T
Bradford and Airedale Teaching PCT
New Mill, Victoria Road, Saltaire, Shipley, West Yorkshire, BD18 3LD
Tel: 01274 366031
This email is intended for the use of the addressee only and may contain
confidential information, copyright material or views/opinions that do
not necessarily reflect those of the organisation. If you receive this
email by mistake please advise the sender immediately. All should be
aware that this email may be subject to public disclosure under the
Freedom of Information Act 2000 and that emails are monitored
periodically.
Sent: Wed 04/10/2006 14:39
The SQL Server provider is intented to work with datastore created with
Map 3D 2007 inside SQL Server 2000 and 2005.
It has it's own geometry storage and spatial indexing mechanism.
Although it could reverse engineer existing database, this would be done
for non-spatial data only as it has no mean to identify geometry
property in the database.
Just wanted to make sure the provider was not being used for what it was
not design for.
RF
Sent: Wednesday, October 04, 2006 2:59 AM
Supported yes - does it work... now that's the question.
From: Gord McKenzie [mailto:gord.mckenzie at canam.com]
Sent: Tue 03/10/2006 22:04
Thanks
Sent: Tuesday, October 03, 2006 1:33 PM
Hello Gord,
I was informed by the ADN that the FDO provider supports: SQL Server
2000 (SP4) and SQL Server 2005.
Warren Medernach
This message has been scanned for viruses by MailControl
<http://bluepages.wsatkins.co.uk/?4318150>
This email and any attached files are confidential and copyright
protected. If you are not the addressee, any dissemination of this
communication is strictly prohibited. Unless otherwise expressly agreed
in writing, nothing stated in this communication shall be legally
binding. <http://www.blackspider.com/>
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061005/3fea3705/attachment.html
More information about the Mapguide_users mailing list
