[mapguide-users] Resource data was not found
    François Van Der Biest
    francois.van-der-biest at onf.fr
    Wed Oct 11 03:48:08 EDT 2006
You might find a solution to your problem here :
http://www.nabble.com/How-to-check-if-session-is-expired--tf2218864.html#a6549987
It took me a lot of time to find this trick.
F.
Cory Gregor a écrit :
> The code is blowing up on this line:  map.Open(ResourceService,
> mgResourceID);
> The browser is telling me " Resource datawas not found:  RuntimeDataResource
> data was not found: ....."
> Is the some IIS config problem maybe?  IIS 6 on Win2k3 Server.
> Here is the code...
>     //String mapDefinition =
> "Library://Samples/FredWeber/Maps/Default.MapDefinition";
>     //String webLayout = "Library://Samples/FredWeber/FredWeber.WebLayout";
>     String sessionId = "";
>     String NoLayers = "No Layers Selected";
>     try
>         MapGuideApi.InitializeSockets();
>         InitializeWebTier();
>         MgUserInformation userInfo = new MgUserInformation("XXXX","YYYY");
>         MgSite site = new MgSite();
>         site.Open(userInfo);
>         sessionId = site.CreateSession();
>         MgSiteConnection siteConnection = new MgSiteConnection();
>         siteConnection.Open(userInfo);
>         MgResourceService ResourceService =
> siteConnection.CreateService(MgServiceType.ResourceService) as
> MgResourceService;
>         MgFeatureService FeatureService =
> siteConnection.CreateService(MgServiceType.FeatureService) as
> MgFeatureService;
>         MgFeatureQueryOptions QueryOptions = new MgFeatureQueryOptions();
>         MgResourceIdentifier mgResourceID = new
> MgResourceIdentifier(mapDefinition);
>         MgMap map = new MgMap();
>         map.Open(ResourceService, mgResourceID);
>         Response.Write("Got here");
>         MgSelection selection = new MgSelection(map);
>         selection.Open(ResourceService, "map");
>         MgReadOnlyLayerCollection Layers = selection.GetLayers();
>         if (Layers.GetCount() > 0)
>             for (int i = 0; i < Layers.GetCount(); i++)
>                 //Only check selected features in the Parcels layer.
>                 MgLayer Layer = Layers.GetItem(i);
>                 if (Layer != null && Layer.GetLayerDefinition() == new
> MgResourceIdentifier("Default_Map Base_727(3)"))
>                     //Create a filter containing the IDs of the selected
>                     //features on this layer
>                     string LayerClassName = Layer.GetFeatureClassName();
>                     string selectionString = selection.GenerateFilter(Layer,
> LayerClassName);
>                     //Get the feature resource for the selected layer
>                     string LayerFeatureId = Layer.GetFeatureSourceId();
>                     MgResourceIdentifier LayerFeatureResource = new
> MgResourceIdentifier(LayerFeatureId);
>                     //Apply the filter to the feature resource for the
>                     // selected layer. This returns
>                     //an MgFeatureReader of all the selected features.
>                     QueryOptions.SetFilter(selectionString);
>                     MgFeatureReader FeatureReader =
> FeatureService.SelectFeatures(LayerFeatureResource, LayerClassName,
> QueryOptions);
>                     //Process each item in the MgFeatureReader, displaying
> the
>                     //owner name and address
>                     while (FeatureReader.ReadNext())
>                         string val = FeatureReader.GetString("FeatureID");
>                         //FeatureReader.GetString("Layer");
>                         Response.Write(val);
>         else
>             Response.Write(NoLayers);
>         MapGuideApi.TerminateSockets();
>     catch (MgException mge)
>         Response.Write(mge.GetMessage());
>         Response.Write(mge.GetDetails());
More information about the Mapguide_users
