[mapguide-users] Resource data was not found
Cory Gregor
cgregor at barkerlemar.com
Wed Oct 11 14:04:02 EDT 2006
Thanks for trying to help F.
I am getting session fine. It keeps telling me that it can not find my map.
But if i take out the resource part of the code the map will load fine.
Thanks,
Cory
François VANDER BIEST wrote:
> You might find a solution to your problem here :
> http://www.nabble.com/How-to-check-if-session-is-expired--tf2218864.html#a6549987
> It took me a lot of time to find this trick.
> F.
> Cory Gregor a écrit :
>> The code is blowing up on this line: map.Open(ResourceService,
>> mgResourceID);
>> The browser is telling me " Resource datawas not found:
>> RuntimeDataResource
>> data was not found: ....."
>> Is the some IIS config problem maybe? IIS 6 on Win2k3 Server.
>> Here is the code...
>> //String mapDefinition =
>> "Library://Samples/FredWeber/Maps/Default.MapDefinition";
>> //String webLayout =
>> "Library://Samples/FredWeber/FredWeber.WebLayout";
>> String sessionId = "";
>> String NoLayers = "No Layers Selected";
>> try
>> MapGuideApi.InitializeSockets();
>> InitializeWebTier();
>> MgUserInformation userInfo = new
>> MgUserInformation("XXXX","YYYY");
>> MgSite site = new MgSite();
>> site.Open(userInfo);
>> sessionId = site.CreateSession();
>> MgSiteConnection siteConnection = new MgSiteConnection();
>> siteConnection.Open(userInfo);
>> MgResourceService ResourceService =
>> siteConnection.CreateService(MgServiceType.ResourceService) as
>> MgResourceService;
>> MgFeatureService FeatureService =
>> siteConnection.CreateService(MgServiceType.FeatureService) as
>> MgFeatureService;
>> MgFeatureQueryOptions QueryOptions = new MgFeatureQueryOptions();
>> MgResourceIdentifier mgResourceID = new
>> MgResourceIdentifier(mapDefinition);
>> MgMap map = new MgMap();
>> map.Open(ResourceService, mgResourceID);
>> Response.Write("Got here");
>> MgSelection selection = new MgSelection(map);
>> selection.Open(ResourceService, "map");
>> MgReadOnlyLayerCollection Layers = selection.GetLayers();
>> if (Layers.GetCount() > 0)
>> for (int i = 0; i < Layers.GetCount(); i++)
>> //Only check selected features in the Parcels layer.
>> MgLayer Layer = Layers.GetItem(i);
>> if (Layer != null && Layer.GetLayerDefinition() == new
>> MgResourceIdentifier("Default_Map Base_727(3)"))
>> //Create a filter containing the IDs of the selected
>> //features on this layer
>> string LayerClassName = Layer.GetFeatureClassName();
>> string selectionString =
>> selection.GenerateFilter(Layer,
>> LayerClassName);
>> //Get the feature resource for the selected layer
>> string LayerFeatureId = Layer.GetFeatureSourceId();
>> MgResourceIdentifier LayerFeatureResource = new
>> MgResourceIdentifier(LayerFeatureId);
>> //Apply the filter to the feature resource for the
>> // selected layer. This returns
>> //an MgFeatureReader of all the selected features.
>> QueryOptions.SetFilter(selectionString);
>> MgFeatureReader FeatureReader =
>> FeatureService.SelectFeatures(LayerFeatureResource, LayerClassName,
>> QueryOptions);
>> //Process each item in the MgFeatureReader,
>> displaying
>> the
>> //owner name and address
>> while (FeatureReader.ReadNext())
>> string val =
>> FeatureReader.GetString("FeatureID");
>> //FeatureReader.GetString("Layer");
>> Response.Write(val);
>> else
>> Response.Write(NoLayers);
>> MapGuideApi.TerminateSockets();
>> catch (MgException mge)
>> Response.Write(mge.GetMessage());
>> Response.Write(mge.GetDetails());
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/Resource-data-was-not-found-tf2419141.html#a6761590
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide_users
