[mapguide-users] Resource data was not found
Cory Gregor cgregor at barkerlemar.com
Wed Oct 11 14:06:58 EDT 2006
Is there something in Studio that i need to do to make the resources part of
the maps work?
Thanks,
Cory
François VANDER BIEST wrote:
> You might find a solution to your problem here :
> http://www.nabble.com/How-to-check-if-session-is-expired--tf2218864.html#a6549987
> It took me a lot of time to find this trick.
> F.
> Cory Gregor a écrit :
>> The code is blowing up on this line:  map.Open(ResourceService,
>> mgResourceID);
>> The browser is telling me " Resource datawas not found:
>> RuntimeDataResource
>> data was not found: ....."
>> Is the some IIS config problem maybe?  IIS 6 on Win2k3 Server.
>> Here is the code...
>>     //String mapDefinition =
>> "Library://Samples/FredWeber/Maps/Default.MapDefinition";
>>     //String webLayout =
>> "Library://Samples/FredWeber/FredWeber.WebLayout";
>>     String sessionId = "";
>>     String NoLayers = "No Layers Selected";
>>     try
>>         MapGuideApi.InitializeSockets();
>>         InitializeWebTier();
>>         MgUserInformation userInfo = new
>> MgUserInformation("XXXX","YYYY");
>>         MgSite site = new MgSite();
>>         site.Open(userInfo);
>>         sessionId = site.CreateSession();
>>         MgSiteConnection siteConnection = new MgSiteConnection();
>>         siteConnection.Open(userInfo);
>>         MgResourceService ResourceService =
>> siteConnection.CreateService(MgServiceType.ResourceService) as
>> MgResourceService;
>>         MgFeatureService FeatureService =
>> siteConnection.CreateService(MgServiceType.FeatureService) as
>> MgFeatureService;
>>         MgFeatureQueryOptions QueryOptions = new MgFeatureQueryOptions();
>>         MgResourceIdentifier mgResourceID = new
>> MgResourceIdentifier(mapDefinition);
>>         MgMap map = new MgMap();
>>         map.Open(ResourceService, mgResourceID);
>>         Response.Write("Got here");
>>         MgSelection selection = new MgSelection(map);
>>         selection.Open(ResourceService, "map");
>>         MgReadOnlyLayerCollection Layers = selection.GetLayers();
>>         if (Layers.GetCount() > 0)
>>             for (int i = 0; i < Layers.GetCount(); i++)
>>                 //Only check selected features in the Parcels layer.
>>                 MgLayer Layer = Layers.GetItem(i);
>>                 if (Layer != null && Layer.GetLayerDefinition() == new
>> MgResourceIdentifier("Default_Map Base_727(3)"))
>>                     //Create a filter containing the IDs of the selected
>>                     //features on this layer
>>                     string LayerClassName = Layer.GetFeatureClassName();
>>                     string selectionString =
>> selection.GenerateFilter(Layer,
>> LayerClassName);
>>                     //Get the feature resource for the selected layer
>>                     string LayerFeatureId = Layer.GetFeatureSourceId();
>>                     MgResourceIdentifier LayerFeatureResource = new
>> MgResourceIdentifier(LayerFeatureId);
>>                     //Apply the filter to the feature resource for the
>>                     // selected layer. This returns
>>                     //an MgFeatureReader of all the selected features.
>>                     QueryOptions.SetFilter(selectionString);
>>                     MgFeatureReader FeatureReader =
>> FeatureService.SelectFeatures(LayerFeatureResource, LayerClassName,
>> QueryOptions);
>>                     //Process each item in the MgFeatureReader,
>> displaying
>> the
>>                     //owner name and address
>>                     while (FeatureReader.ReadNext())
>>                         string val =
>> FeatureReader.GetString("FeatureID");
>>                         //FeatureReader.GetString("Layer");
>>                         Response.Write(val);
>>         else
>>             Response.Write(NoLayers);
>>         MapGuideApi.TerminateSockets();
>>     catch (MgException mge)
>>         Response.Write(mge.GetMessage());
>>         Response.Write(mge.GetDetails());
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/Resource-data-was-not-found-tf2419141.html#a6761638
Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
More information about the Mapguide_users mailing list
