[mapguide-users] MapGuide Open Source 1.0.2 Released
Tom Fukushima tom.fukushima at autodesk.com
Sun Oct 15 17:41:06 EDT 2006
Hi Jason,
I updated the downloads page with what needs to be done to get the server to run.
This is not a secret ploy to get everyone to use Linux :)
Regards,
Tom
Here is the note for the Windows installer:
NOTE: This installer is installing the FDO files in the wrong directory. An updated installer that resolves the issue will be posted here shortly. Until then, to get the server to work, you will need to manually move all the files in
C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\bin
to
(i.e., up one directory). Also note that the providers.xml file in the same directory, must be edited so that the two occurrences of C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\bin are changed to C:\Program Files\MapGuideOpenSource\Server\Bin\FDO.
	-----Original Message-----
	From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
	Sent: Sun 2006/10/15 14:57
	Cc:
	Subject: RE: [mapguide-users] MapGuide Open Source 1.0.2 Released
	Hi MapGuide Team :)
	I'm not sure if this was an artefact from a previous install, but the MapGuide service did not start properly after the uninstall/reinstall.  Running the service in interactive mode, I got the following:
	Running the server interactively as an application instead of as a service.
	(2812|3864) An exception occurred in FDO component.
	Failed to load FDO library.
	Exception occurred in method MgServer.svc at line 312 in file c:\build_tux_area\mgdev_opensource\server\src\core\Server.cpp
	I found that I could get around this by altering the file serverconfig.ini, which was found in C:\Program Files\MapGuideOpenSource\Server\bin, setting the FdoPath to a new location.
	Old setting:
	FdoPath                            =C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\
	New setting:
	FdoPath                            =C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\bin\
	Jason
  _____
	Sent: Sat 2006-10-14 10:52 PM
	To: announce at mapguide.osgeo.org; users at mapguide.osgeo.org
	Subject: [mapguide-users] MapGuide Open Source 1.0.2 Released
	We are pleased to announce the release of MapGuide Open Source 1.0.2 <https://mapguide.osgeo.org/downloads.html> . This release contains numerous bug fixes and performance enhancements. For more information see the release notes <https://www.osgeo.org/files/documents/12/290/ReleaseNotes1.0.2.html>  and the website updates. Like the previous release this one includes an updated batch of FDO Provider binaries that can be downloaded for use with the install of MapGuide.
	The MapGuide Team
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061015/1a590e7c/attachment.html
More information about the Mapguide_users mailing list
