[mapguide-users] MapGuide Open Source 1.0.2 Released
Tom Fukushima tom.fukushima at autodesk.com
Sun Oct 15 17:58:06 EDT 2006
Hi Jason,
Thanks for serverconfig.ini fix as well.  In case you were wondering why I chose this other more complicated method of moving files around, it's because some of the other documentation that we have depends on the files being in the FDO directory.
For the serverconfig.ini fix method that you propose, if you would like to add the extra providers (ODBC, OGR, etc.), they should now also be put in the Server\Bin\FDO\bin directory as opposed to the Server\Bin\FDO directory that is described in the ReadMe notes.
Thanks
Tom
	-----Original Message-----
	Sent: Sun 2006/10/15 15:41
	To: users at mapguide.osgeo.org; users at mapguide.osgeo.org
	Cc:
	Subject: RE: [mapguide-users] MapGuide Open Source 1.0.2 Released
	Hi Jason,
	I updated the downloads page with what needs to be done to get the server to run.
	This is not a secret ploy to get everyone to use Linux :)
	Regards,
	Tom
	Here is the note for the Windows installer:
	NOTE: This installer is installing the FDO files in the wrong directory. An updated installer that resolves the issue will be posted here shortly. Until then, to get the server to work, you will need to manually move all the files in
	C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\bin
	to
	(i.e., up one directory). Also note that the providers.xml file in the same directory, must be edited so that the two occurrences of C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\bin are changed to C:\Program Files\MapGuideOpenSource\Server\Bin\FDO.
		From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
		Sent: Sun 2006/10/15 14:57
		Cc:
		Hi MapGuide Team :)
		I'm not sure if this was an artefact from a previous install, but the MapGuide service did not start properly after the uninstall/reinstall.  Running the service in interactive mode, I got the following:
		Running the server interactively as an application instead of as a service.
		(2812|3864) An exception occurred in FDO component.
		Failed to load FDO library.
		Exception occurred in method MgServer.svc at line 312 in file c:\build_tux_area\mgdev_opensource\server\src\core\Server.cpp
		I found that I could get around this by altering the file serverconfig.ini, which was found in C:\Program Files\MapGuideOpenSource\Server\bin, setting the FdoPath to a new location.
		Old setting:
		FdoPath                            =C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\
		New setting:
		FdoPath                            =C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\bin\
		Jason
  _____
		Sent: Sat 2006-10-14 10:52 PM
		To: announce at mapguide.osgeo.org; users at mapguide.osgeo.org
		Subject: [mapguide-users] MapGuide Open Source 1.0.2 Released
		We are pleased to announce the release of MapGuide Open Source 1.0.2 <https://mapguide.osgeo.org/downloads.html> . This release contains numerous bug fixes and performance enhancements. For more information see the release notes <https://www.osgeo.org/files/documents/12/290/ReleaseNotes1.0.2.html>  and the website updates. Like the previous release this one includes an updated batch of FDO Provider binaries that can be downloaded for use with the install of MapGuide.
		The MapGuide Team
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061015/b71415a9/attachment.bin
More information about the Mapguide_users mailing list
