[mapguide-users] MapGuide Open Source 1.0.2 Released
Jason Birch
Jason.Birch at nanaimo.ca
Sun Oct 15 19:58:51 EDT 2006
Hi Tom,
I like the "moving files" fix better anyway. I thought that there might have been some reason for the files to be in the bin directory. Like a directive to make the directory structure as complicated as possible :)
Jason
Sent: Sun 2006-10-15 2:58 PM
Subject: RE: [mapguide-users] MapGuide Open Source 1.0.2 Released
Hi Jason,
Thanks for serverconfig.ini fix as well. In case you were wondering why I chose this other more complicated method of moving files around, it's because some of the other documentation that we have depends on the files being in the FDO directory.
For the serverconfig.ini fix method that you propose, if you would like to add the extra providers (ODBC, OGR, etc.), they should now also be put in the Server\Bin\FDO\bin directory as opposed to the Server\Bin\FDO directory that is described in the ReadMe notes.
Thanks
Tom
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061015/fdf2d962/attachment.bin
More information about the Mapguide_users
