[mapguide-users] FDO - MySQL issues/questions
Kerndata.com support at kerndata.com
Tue Oct 17 19:58:55 EDT 2006
Unexpected Error in contacting site URLBrent,
I upgraded to 5.0.26-max and now I receive:
"An exception occured in FDO component.
RDBMS:"
and then:
"No data stores found."
Is there some other item I'm not understanding here?
Please advise,
Eric Brown
Kerndata.com
5500 Ming Avenue
Suite 160
Bakersfield, CA  93309
888.871.7205
888.603.6279 fax
http://www.kerndata.com
  ----- Original Message -----
  Sent: Tuesday, October 17, 2006 3:01 PM
  Subject: FW: [mapguide-users] FDO - MySQL issues/questions
  MySQL 4.1.20 would be older than the minimum version supported by the MySQL provider. I'm not exactly sure what the minimum is (does anyone else know off-hand?). However, upgrading to 5.0.15 or later would get rid of the error.
  The MySQL provider relies on some information_schema tables (which were introduced in version 5) to get information on tables, columns, etc.
  -----Original Message-----
  From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
  Sent: Tuesday, October 17, 2006 3:35 PM
  Subject: RE: [mapguide-users] FDO - MySQL issues/questions
  I believe that the MySQL provider requires that a schema be defined, though I haven't tried it myself.
  Currently, the only way that I know of for doing this is via Autodesk's Map 3D.  The scripts for creating the schema tables are in FDO repository I think, so you might be able to reverse engineer the process and create your own.
  https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/com/
  Jason
  Sent: Tuesday, October 17, 2006 10:18
  Subject: [mapguide-users] FDO - MySQL issues/questions
  I'm attempting to configure a MySQL connection in MapGuide Studio 2007 using the MySQL FDO I downloaded and installed from osgeo.org.
  It appears that the "Test Connection" functions properly (I think) but the little box that shows whatever message it's supposed to show doesn't show a message - just a little yield sign with no message in the box (on user permissions errors I receive an actual message).
  At any rate, when I ultimately enter the correct connection information and attempt to browse for a Data store - I receive the following message:
  "An exception occurred in FDO component.
  RDBMS: Table 'information_schema.schemata' doesn't exist"
  And then -
  "No data stores found"
  Any insight into this error - or how to actually connect to my MySQL db would be greatly appreciated.
  DB = MySQL 4.1.20
  Please advise,
  Eric Brown
  Kerndata.com
  5500 Ming Avenue
  Suite 160
  888.871.7205
  888.603.6279 fax
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061017/d12dc8e1/attachment.html
More information about the Mapguide_users mailing list
