[mapguide-users] FDO - MySQL issues/questions
    Chris Gountanis
    cgountanis at mpower-tech.com
    Wed Oct 18 09:41:16 EDT 2006
I use MySQL 5.0.22 Community NT and everything works fine. I can at least
verify that. I have used Map 2007 to bulk copy SHP files to MySQL and the
only problem was authoring the layers. The preview shows nothing even with
the correct Cord Sys. Once I got to the Map Layout and manually entered the
proper X-Y everything works smooth.
Chris
-----Original Message-----
From: Kerndata.com [mailto:support at kerndata.com]
Sent: Tuesday, October 17, 2006 6:59 PM
Subject: Re: [mapguide-users] FDO - MySQL issues/questions
Brent,
I upgraded to 5.0.26-max and now I receive:
"An exception occured in FDO component.
RDBMS:"
and then:
"No data stores found."
Is there some other item I'm not understanding here?
Please advise,
Eric Brown
Kerndata.com
5500 Ming Avenue
Suite 160
Bakersfield, CA  93309
888.871.7205
888.603.6279 fax
http://www.kerndata.com
	----- Original Message -----
	From: Brent Robinson <mailto:brent.robinson at autodesk.com>
	Sent: Tuesday, October 17, 2006 3:01 PM
	Subject: FW: [mapguide-users] FDO - MySQL issues/questions
	MySQL 4.1.20 would be older than the minimum version supported by
the MySQL provider. I'm not exactly sure what the minimum is (does anyone
else know off-hand?). However, upgrading to 5.0.15 or later would get rid of
the error.
	The MySQL provider relies on some information_schema tables (which
were introduced in version 5) to get information on tables, columns, etc.
	From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
	Sent: Tuesday, October 17, 2006 3:35 PM
	Subject: RE: [mapguide-users] FDO - MySQL issues/questions
	I believe that the MySQL provider requires that a schema be defined,
though I haven't tried it myself.
	Currently, the only way that I know of for doing this is via
Autodesk's Map 3D.  The scripts for creating the schema tables are in FDO
repository I think, so you might be able to reverse engineer the process and
create your own.
https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/G
enericRdbms/com/
	Jason
	Sent: Tuesday, October 17, 2006 10:18
	Subject: [mapguide-users] FDO - MySQL issues/questions
	I'm attempting to configure a MySQL connection in MapGuide Studio
2007 using the MySQL FDO I downloaded and installed from osgeo.org.
	It appears that the "Test Connection" functions properly (I think)
but the little box that shows whatever message it's supposed to show doesn't
show a message - just a little yield sign with no message in the box (on
user permissions errors I receive an actual message).
	At any rate, when I ultimately enter the correct connection
information and attempt to browse for a Data store - I receive the following
message:
	"An exception occurred in FDO component.
	RDBMS: Table 'information_schema.schemata' doesn't exist"
	And then -
	"No data stores found"
	Any insight into this error - or how to actually connect to my MySQL
db would be greatly appreciated.
	DB = MySQL 4.1.20
	Please advise,
	Eric Brown
	Kerndata.com
	5500 Ming Avenue
	Suite 160
	888.871.7205
	888.603.6279 fax
More information about the Mapguide_users
