[mapguide-users] RE: PHP version
Jason Birch Jason.Birch at nanaimo.ca
Wed Oct 18 03:59:34 EDT 2006
It's difficult to troubleshoot your problems with the level of details you're providing.
What version of MapGuide are you trying to install?  I would suggest starting with MapGuide Open Source 1.0.2, as it has a much cleaner installation than any of the earlier versions.  Either that or waiting for the SP1 from Autodesk.  There are known issues with some locales in earlier versions of MapGuide.
What operating system are you running?
Are you able to login to the Map Administrator?
Are you able to login to mapguide/mapagent/index.html and get a value for the EnumerateResources query?
Where are you unable to see the map?  In Studio?  In the sample application?
What data are you looking at?  Sheboygan?  Your own data?
Is there any other information you can provide that could help with the resolution of this problem?
Jason
Sent: Tue 2006-10-17 11:40 PM
Subject: [mapguide-users] RE: PHP version
Hi Jason,
Thanks for the reply. I have try to install mapguide 2007 with IIS>PHP
config.
But when i try to view the map it shows nothing. I have follow the
installation instruction bt still nothing.
I hope you can give me solution. I am looking forward for your reply and
thank you.
Regards,
Kencana
Jason Birch wrote:
> MapGuide Open Source (and I believe Enterprise) are reliant on PHP version
> 5.0.5.
> At least, that was the case last time I checked (several users have found
> this out by running with newer unsupported versions of PHP) and PHP 5.0.5
> is the version which is bundled with MapGuide.
> Jason
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Tue 2006-10-17 9:35 PM
> Subject: [mapguide-users] PHP version
> Hi guys,
> I am new to this "Autodesk Mapguide 2007" and I want to ask about the php
> version which compatible to this software. I am looking forward for the
> reply and thank you very much.
> Regards,
> Kencana
> http://www.nabble.com/PHP-version-tf2464139.html#a6869321
> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context: http://www.nabble.com/PHP-version-tf2464139.html#a6870320
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061018/c4fae53c/attachment.bin
More information about the Mapguide_users mailing list
