PHP version
Kencana bluesky_dyx at hotmail.com
Wed Oct 18 05:12:06 EDT 2006
Hi Jason,
I guess I have install the old version of mapguide. first of all sorry if I
am troubling you. can I know the step of installing the opensource 1.0.2?I
download tar file for that. but I am confused in how to install it.
currently I am using windows server 2003. I am not able to log in into map
administrator, where it didnt show anything only blank page.and I am trying
to view the shebboygan map but it shows nothing. I am looking forward for
your reply.
Regards,
Kencana
Jason Birch wrote:
> It's difficult to troubleshoot your problems with the level of details
> you're providing.
> What version of MapGuide are you trying to install?  I would suggest
> starting with MapGuide Open Source 1.0.2, as it has a much cleaner
> installation than any of the earlier versions.  Either that or waiting for
> the SP1 from Autodesk.  There are known issues with some locales in
> earlier versions of MapGuide.
> What operating system are you running?
> Are you able to login to the Map Administrator?
> Are you able to login to mapguide/mapagent/index.html and get a value for
> the EnumerateResources query?
> Where are you unable to see the map?  In Studio?  In the sample
> application?
> What data are you looking at?  Sheboygan?  Your own data?
> Is there any other information you can provide that could help with the
> resolution of this problem?
> Jason
> ________________________________
> From: Kencana [mailto:bluesky_dyx at hotmail.com]
> Sent: Tue 2006-10-17 11:40 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] RE: PHP version
> Hi Jason,
> Thanks for the reply. I have try to install mapguide 2007 with IIS>PHP
> config.
> But when i try to view the map it shows nothing. I have follow the
> installation instruction bt still nothing.
> I hope you can give me solution. I am looking forward for your reply and
> thank you.
> Regards,
> Kencana
> Jason Birch wrote:
>> MapGuide Open Source (and I believe Enterprise) are reliant on PHP
>> version
>> 5.0.5.
>> At least, that was the case last time I checked (several users have found
>> this out by running with newer unsupported versions of PHP) and PHP 5.0.5
>> is the version which is bundled with MapGuide.
>> Jason
>> Sent: Tue 2006-10-17 9:35 PM
>> Subject: [mapguide-users] PHP version
>> Hi guys,
>> I am new to this "Autodesk Mapguide 2007" and I want to ask about the php
>> version which compatible to this software. I am looking forward for the
>> reply and thank you very much.
>> Regards,
>> Kencana
>> View this message in context:
>> http://www.nabble.com/PHP-version-tf2464139.html#a6869321
>> Sent from the OSGeo MapGuide mailing list archive at Nabble.com.
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
> http://www.nabble.com/PHP-version-tf2464139.html#a6870320
View this message in context: http://www.nabble.com/PHP-version-tf2464139.html#a6872289
More information about the Mapguide_users mailing list
