[mapguide-users] FDO - MySQL issues/questions
Brent Robinson
brent.robinson at autodesk.com
Wed Oct 18 15:46:42 EDT 2006
Hi Eric,
Could you do a describe on the information_schema.schemata table and
send me the results?
Unfortunately, I don't yet have MapGuide on my machine but I tried
installing 5.0.26 and accessing it with an FDO test program. I just
tried a few simple things ( listing datatores, opening a connection,
describing schemas ) but it worked ok.
The main difference is that mine was a fresh install while yours would
have been an upgrade from 4. I'm wondering if the information_schema
ends up a bit different in either case.
Brent.
-----Original Message-----
From: Kerndata.com [mailto:support at kerndata.com]
Sent: Tuesday, October 17, 2006 7:59 PM
Subject: Re: [mapguide-users] FDO - MySQL issues/questions
Brent,
I upgraded to 5.0.26-max and now I receive:
"An exception occured in FDO component.
RDBMS:"
and then:
"No data stores found."
Is there some other item I'm not understanding here?
Please advise,
Eric Brown
Kerndata.com
5500 Ming Avenue
Suite 160
Bakersfield, CA 93309
888.871.7205
888.603.6279 fax
http://www.kerndata.com
----- Original Message -----
From: Brent Robinson <mailto:brent.robinson at autodesk.com>
Sent: Tuesday, October 17, 2006 3:01 PM
Subject: FW: [mapguide-users] FDO - MySQL issues/questions
MySQL 4.1.20 would be older than the minimum version supported
by the MySQL provider. I'm not exactly sure what the minimum is (does
anyone else know off-hand?). However, upgrading to 5.0.15 or later would
get rid of the error.
The MySQL provider relies on some information_schema tables
(which were introduced in version 5) to get information on tables,
columns, etc.
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Tuesday, October 17, 2006 3:35 PM
Subject: RE: [mapguide-users] FDO - MySQL issues/questions
I believe that the MySQL provider requires that a schema be
defined, though I haven't tried it myself.
Currently, the only way that I know of for doing this is via
Autodesk's Map 3D. The scripts for creating the schema tables are in
FDO repository I think, so you might be able to reverse engineer the
process and create your own.
https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Provide
rs/GenericRdbms/com/
Jason
_____
Sent: Tuesday, October 17, 2006 10:18
Subject: [mapguide-users] FDO - MySQL issues/questions
I'm attempting to configure a MySQL connection in MapGuide
Studio 2007 using the MySQL FDO I downloaded and installed from
osgeo.org.
It appears that the "Test Connection" functions properly (I
think) but the little box that shows whatever message it's supposed to
show doesn't show a message - just a little yield sign with no message
in the box (on user permissions errors I receive an actual message).
At any rate, when I ultimately enter the correct connection
information and attempt to browse for a Data store - I receive the
following message:
"An exception occurred in FDO component.
RDBMS: Table 'information_schema.schemata' doesn't exist"
And then -
"No data stores found"
Any insight into this error - or how to actually connect to my
MySQL db would be greatly appreciated.
DB = MySQL 4.1.20
Please advise,
Eric Brown
Kerndata.com
5500 Ming Avenue
Suite 160
888.871.7205
888.603.6279 fax
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061018/cc69a94d/attachment.html
More information about the Mapguide_users
