[mapguide-users] FDO - MySQL issues/questions
Kerndata.com
support at kerndata.com
Wed Oct 18 17:51:55 EDT 2006
Unexpected Error in contacting site URLBrent,
Here's a Dump of the SCHEMATA table
-- Table: SCHEMATA
CREATE TABLE `SCHEMATA`
`CATALOG_NAME` varchar (512),
`SCHEMA_NAME` varchar (64) NOT NULL,
`DEFAULT_CHARACTER_SET_NAME` varchar (64) NOT NULL,
`DEFAULT_COLLATION_NAME` varchar (64) NOT NULL,
`SQL_PATH` varchar (512)
) CHARACTER SET utf8 COLLATE utf8_general_ci;
-- GO
BEGIN;
-- GO
-- Dumping Triggers
SET FOREIGN_KEY_CHECKS=1;
-- GO
Eric Brown
Kerndata.com
5500 Ming Avenue
Suite 160
Bakersfield, CA 93309
888.871.7205
888.603.6279 fax
http://www.kerndata.com
----- Original Message -----
Sent: Wednesday, October 18, 2006 12:46 PM
Subject: RE: [mapguide-users] FDO - MySQL issues/questions
Hi Eric,
Could you do a describe on the information_schema.schemata table and send me the results?
Unfortunately, I don't yet have MapGuide on my machine but I tried installing 5.0.26 and accessing it with an FDO test program. I just tried a few simple things ( listing datatores, opening a connection, describing schemas ) but it worked ok.
The main difference is that mine was a fresh install while yours would have been an upgrade from 4. I'm wondering if the information_schema ends up a bit different in either case.
Brent.
-----Original Message-----
From: Kerndata.com [mailto:support at kerndata.com]
Sent: Tuesday, October 17, 2006 7:59 PM
Subject: Re: [mapguide-users] FDO - MySQL issues/questions
Brent,
I upgraded to 5.0.26-max and now I receive:
"An exception occured in FDO component.
RDBMS:"
and then:
"No data stores found."
Is there some other item I'm not understanding here?
Please advise,
Eric Brown
Kerndata.com
5500 Ming Avenue
Suite 160
888.871.7205
888.603.6279 fax
Sent: Tuesday, October 17, 2006 3:01 PM
Subject: FW: [mapguide-users] FDO - MySQL issues/questions
MySQL 4.1.20 would be older than the minimum version supported by the MySQL provider. I'm not exactly sure what the minimum is (does anyone else know off-hand?). However, upgrading to 5.0.15 or later would get rid of the error.
The MySQL provider relies on some information_schema tables (which were introduced in version 5) to get information on tables, columns, etc.
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Tuesday, October 17, 2006 3:35 PM
I believe that the MySQL provider requires that a schema be defined, though I haven't tried it myself.
Currently, the only way that I know of for doing this is via Autodesk's Map 3D. The scripts for creating the schema tables are in FDO repository I think, so you might be able to reverse engineer the process and create your own.
https://fdordbms.osgeo.org/source/browse/fdordbms/branches/3.2.x/Providers/GenericRdbms/com/
Jason
Sent: Tuesday, October 17, 2006 10:18
Subject: [mapguide-users] FDO - MySQL issues/questions
I'm attempting to configure a MySQL connection in MapGuide Studio 2007 using the MySQL FDO I downloaded and installed from osgeo.org.
It appears that the "Test Connection" functions properly (I think) but the little box that shows whatever message it's supposed to show doesn't show a message - just a little yield sign with no message in the box (on user permissions errors I receive an actual message).
At any rate, when I ultimately enter the correct connection information and attempt to browse for a Data store - I receive the following message:
"An exception occurred in FDO component.
RDBMS: Table 'information_schema.schemata' doesn't exist"
And then -
"No data stores found"
Any insight into this error - or how to actually connect to my MySQL db would be greatly appreciated.
DB = MySQL 4.1.20
Please advise,
Eric Brown
Kerndata.com
5500 Ming Avenue
Suite 160
888.871.7205
888.603.6279 fax
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061018/2657b6e3/attachment.html
More information about the Mapguide_users
