[mapguide-users] MapGuide Open Source 1.0.2 Released
Tom Fukushima tom.fukushima at autodesk.com
Thu Oct 19 11:20:41 EDT 2006
Hi Francisco,
Yes, there is an SP1 for MapGuide Enterprise coming that will have the updated FDO dlls; so you won't have to move DLLs from Autodesk Map 3D 2007 SP3 to Autodesk MapGuide Enterprise. Please note that we have not tested the Map SP3 FDO DLLs with MapGuide and you may run into some problems. Although in theory the DLLs are interchangeable, in practice some incompatibilities *may* arise.
Tom
  _____
From: Francisco Javier Rojas Duran [mailto:francisco.rojas at dasoft.com.mx]
Sent: Wednesday, October 18, 2006 11:57 AM
To: Tom Fukushima
Cc: users at mapguide.osgeo.org
Subject: RE: [mapguide-users] MapGuide Open Source 1.0.2 Released
Importance: High
Hi Tom:
I am wondering why today there is a MGOS version 1.0.2 and a Service Pack 3 for Adsk Map 3D 2007 which enables FDO 3.1 Providers to connect to Oracle DB 10g R2 with an Oracle Client 10g R2, and there is not an updated version of Adsk MapGuide Ent 2007, I have manually update the FDO Providers 3.1 which originally comes with MGEnt with the newer ones of Map 3D 2007 SP3 (but this only works for the Windows version).
So there is a plan of release a major/minor version/revision/service pack for Adsk MapGuideEnterprise?
Also where can I find the supported coordinated systems for the MapGuide WMS Server, because I have several issues working with UTM CRS.
Francisco Javier Rojas Durán
IT Manager - Oracle Specialist
Grupo DaSoft S.A. de C.V.
  _____
De: Tom Fukushima [mailto:tom.fukushima at autodesk.com]
Enviado el: Domingo, 15 de Octubre de 2006 04:41 p.m.
Para: users at mapguide.osgeo.org; users at mapguide.osgeo.org
Asunto: RE: [mapguide-users] MapGuide Open Source 1.0.2 Released
Hi Jason,
I updated the downloads page with what needs to be done to get the server to run.
This is not a secret ploy to get everyone to use Linux :)
Regards,
Tom
Here is the note for the Windows installer:
NOTE: This installer is installing the FDO files in the wrong directory. An updated installer that resolves the issue will be posted here shortly. Until then, to get the server to work, you will need to manually move all the files in
C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\bin
to
(i.e., up one directory). Also note that the providers.xml file in the same directory, must be edited so that the two occurrences of C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\bin are changed to C:\Program Files\MapGuideOpenSource\Server\Bin\FDO.
	-----Original Message-----
	From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
	Sent: Sun 2006/10/15 14:57
	Cc:
	Hi MapGuide Team :)
	I'm not sure if this was an artefact from a previous install, but the MapGuide service did not start properly after the uninstall/reinstall.  Running the service in interactive mode, I got the following:
	Running the server interactively as an application instead of as a service.
	(2812|3864) An exception occurred in FDO component.
	Failed to load FDO library.
	Exception occurred in method MgServer.svc at line 312 in file c:\build_tux_area\mgdev_opensource\server\src\core\Server.cpp
	I found that I could get around this by altering the file serverconfig.ini, which was found in C:\Program Files\MapGuideOpenSource\Server\bin, setting the FdoPath to a new location.
	Old setting:
	FdoPath                            =C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\
	New setting:
	FdoPath                            =C:\Program Files\MapGuideOpenSource\Server\Bin\FDO\bin\
	Jason
  _____
	Sent: Sat 2006-10-14 10:52 PM
	To: announce at mapguide.osgeo.org; users at mapguide.osgeo.org
	Subject: [mapguide-users] MapGuide Open Source 1.0.2 Released
	We are pleased to announce the release of MapGuide Open Source 1.0.2 <https://mapguide.osgeo.org/downloads.html> . This release contains numerous bug fixes and performance enhancements. For more information see the release notes <https://www.osgeo.org/files/documents/12/290/ReleaseNotes1.0.2.html>  and the website updates. Like the previous release this one includes an updated batch of FDO Provider binaries that can be downloaded for use with the install of MapGuide.
	The MapGuide Team
URL: http://lists.osgeo.org/pipermail/mapguide_users/attachments/20061019/288b9336/attachment.html
More information about the Mapguide_users mailing list
