[mapguide-users] Webstudio and local coordinate systems
    Michaela Schneeberger
    michaela.schneeberger at eur.autodesk.com
    Thu Oct 19 04:53:58 EDT 2006
Hi all,
I'm testing Webstudio with my own local german dataset.
Loading packages was ok, but I got an error because of an invalid coordinatesystem.
In the dataset Gauß-Krüger 4 was used and I've got the following error message:
The coordinate system is invalid. PROJCS["GK-S4-R95",GEOGCS["LL-RAUEN95",DATUM["RAUEN-95",SPHEROID["BESSEL",6377397,155,299,15281535],TOWGS84[582,0000,105,0000,414,0000,-1,040000,-0,350000,3,080000,8,30000000]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Gauss_Kruger"],PARAMETER["false_easting",4500000,000],PARAMETER["false_northing",0,000],PARAMETER["scale_factor",1,000000000000],PARAMETER["central_meridian",12,00000000000000],PARAMETER["latitude_of_origin",0,00000000000000],UNIT["Meter",1,00000000000000]] Could not create coordinate system forward transformation with specified coordinate systems. Exception occurred in method MgCoordinateSystem.MgCoordinateSystem at line 76 in file c:\build_tux_area\mgdev_opensource\common\service\coordinatesystem\CoordinateSystem.cpp
Does this mean Webstudio only supports certain coordinatesystems or have I'm done something wrong?
Thanks a lot
michaela
More information about the Mapguide_users
